Here’s an example to illustrate why a unit of
energy scaled by a rated consumption ratio for the specific car wins hands down against all alternatives.
You arrive at the airport rental car lot, and they say “pick any Tesla Model 3 you like”. The weather is nice and you drive like a grandma, so you don’t care if it’s performance, AWD, or RWD. You need to deliver a package in person and immediately return to catch a connecting flight. Top secret spy stuff here. You have to obey the speed limit so you don’t get noticed by police. You have no time to charge at the destination nor time for a detour to charge. Your destination is 100 mi away, no elevation change, so you want to drive 200 mi flat, there, then back again. You’ve calculated that you only have 30s to decide which car to select and be able to make the round trip and still catch your flight.
Yes this is a ridiculous contrived experiment ... but it’s a setup just to illustrate to everyone that “rated miles” is *the* ONLY choice here...
There are 6 cars. None have badges. Which do you choose based only on a quick glance at the gauge, where:
- Display says 75%
- Display says 64%
- Display says “250 estimated miles” (based on last X miles of driving)
- Display says 48.8 kWh
- Display says 43.8 kWh
- Display says “210 rated miles”
Options 3, 4 & 5 don’t exist, but they have been discussed as alternatives, possibly superior even.
With a quick glance at these cars, which one would you choose?
Which one can make it your 200 mi round trip?
Can more than one of them make it? If so, which has the most safety cushion?
(1) 75% sounds like more than (2) 64%, is it? What trim? What’s 100%? Is the range degraded? 75% of 240 SR+ is only 180. Not good enough.
64% of 310 is 198.
Neither of these has 200 rated miles remaining. If the LR had 65% it mignt ... unless it was degraded by 1%.
(4) 48.8 kWh is useless unless you know the trim and the constant. It’s an LR AWD at 245 Wh/mi and would only have 199 miles, that’s not enough.
(5) has even less energy at 43.8 kWh, so it’s no good, right? Well, actually, it’s an SR+ at 219 Wh/mi, it has 200 rated miles which is a smidge more than (4) even with a -5 kWh handicap!
(3) has the biggest number though, 250(!), so take that one, right? Well... what did the last X miles of driving look like? Do we even know what X is? Even if we know, it’s 30 miles ... do we know if the car was driven 30 comparable flat miles to our projected flat trip? Nope, it just descended 30 miles and only has 10 kWh left! To infinity and beyond!
So only (6) is guaranteed to have more than 200 rated miles, since, you know, the display actually tells you it has 210 rated miles.
Not some cryptic x% of some 100% value you don’t know for sure, nor some cryptic kWh.
For bonus you could have choice (7) be the best choice and it could say “100 estimated miles” but have just come up a steep climb and actually have the most range of all.
TL; DR
Rated miles IS energy for your specific car scaling kWh by appropriate factors so that it’s the same regardless of degradation or even in any trim you look at.
If you drive like an EPA grandma, you’ll get that range. If you drive even slower, you’ll get more, if you drive faster you’ll get less. Yes this is variable. All the other choices are too ... but they depend on variables out of your present control—past driving pattern, who drove your car last? Your lead foot brother or your grandma? From where? Uphill, downhill?
% requires you know what ‘100%’ is. This can change any day, even if you think you know it. Why use something that changes day to day when you can use something that’s consistent, repeatable and accurate day to day?
kWh can be equivalent, *if* you know the constant. It’s different for every car. If you own 2 different ones or are choosing a rental like above, it’s more difficult to compare. In the scenario above, who cares if the Model X has 50 kWh left, the SR+ with only 40 kWh will drive way further.
Rated miles is the great, accurate, consistent, repeatable, equalizer.
All hail the rated miles, bow before them.
Bow I said!
