Vines
Activation of the remote battery disconnect button, while the grid is down will take the system down such that it cannot return until the grid does or it is dark/jump started.How did the system end up in that circumstance?
I thought this thread was for the case of off grid and PWs offline because they hit the low charge level self-protection limit. And then you have to do a "cold start" to bring them back online, presumably with all loads turned off and the sun shining, so they can reestablish the microgrid and let the PV inverters sync and start charging them again.
Cheers, Wayne
Also if the grid is down and all powerwall breakers and switches are off it will need a darkstart if the gateway is reset. Not sure of the exact combination here but have seen a customer in this state who had no button to activate and started turning things off, then tried a gateway reset. Their system could never return on its own after the TEG was reset with the internal button.
