This is almost certainly wrong, even if some (or all) of the improvement is "only" from software updates (firmware motor driver efficiency improvements are very real), and there actually are no hardware changes (to be clear, it's been confirmed that the AWD 2021 still has the 990 motor, not the 980, so that hardware change did NOT happen as I speculated
could have happened in the first post).
Just a visual reminder to those following along (copied from the first post).
@TimothyHW3 has me on ignore AFAIK (since he doesn't like it when someone tries to correct minor things he says that are wrong (a lot of what he says is correct, but not all)), so he won't see this, but at least others will.
The highlights show the efficiency. UDDS is city, Hwy FET is "highway."
Feel free to draw your own conclusions. Remember these are raw numbers, so will likely be better than anything you ever see in reality unless you drive at a steady speed of 20-30mph. But they are real, measured numbers, under controlled (supposed to be identical) conditions.
By following the link in the first post, you can find out as much as you'd ever want to know about how the car does on other cycles.
