Price is $500, including install and alignment. I asked what the alignment kit looks includes, and specifically said I really don't want to pay a few hundred bucks for some washers. They said the shims "will look like washers".
Curious to hear how thick these "shims" need to be.
Here is a screenshot of parts3xpress's video and you can sort of see the shim behind the upper control arm mount. I hear what others are saying about it needing to match the mating surface, but round really is the mating surface. I think the biggest consideration would be material. If it's aluminum on aluminum, you will not want to use steel washers/spacers.
I may just bite the bullet and have parts3xpress do the alignment with their spacers, but I want to see them first.
The bolts are already steel. I seriously doubt there's an galvanic issue here given there's no electron differential in this case. I would not go with an aluminum shim. It will compress over time and the bolts will become loose. Yes, the subframe is aluminum, but the structure has far more cross section and won't permanently compress as easily.
Also, did they say whether the bolts are stock or did they source longer bolts?
$500 isn't a bad deal if you consider it's basically a full service solution. I personally wouldn't spend $500 on it but I can see how some might. My only other concern is if they have Toolbox 3 to redo the ride height calibration which is part of the alignment....which if they do, you can also effect a lowering without having to use different length links. You just lie in the software and add an inch to every height measurement if you want to also lower the vehicle.
