Starbase: Boca Chica/Brownsville SpaceX Site
Is the pile driving equipment at the left side of this image located where the new OLM/launch tower will be built?
Yes, that's the expectation. RGV said that the vehicle is drilling holes for rebar cages, but the holes are being covered over with dirt. The rebar cages are visible to the lower left of the vehicle, and there's even a crane on site to lift them, but I guess they don't have access to the concrete pouring hardware so they have to wait.
For reference, that black wall is the one with the GATEWAY TO MARS sign (no idea why it's black on this side). I won't at all be surprised to see that torn down. Stuff doesn't seem to last long around Starbase.
Reactions: MitchMitch
Another Starship Gazer image showing the lines that deliver various gases up the launch tower. This image is from section 3 of the second launch tower, currently staged for road transport from Brownsville to Starbase.
GOX is gaseous Oxygen and GN2 is gaseous Nitrogen. MEOP is maximum expected operating pressure.
There's a 30 BAR GCH4 line to the right of these. I'm guessing that the 400 bar lines are the supplies and the 30 bar are the returns.
400 bar is 5800 psi.
There are two slender Argon lines on the left. The one just cut off is 100% Argon and the visible one is 75% Argon. For welding, apparently.
There is also a Helium line.
Interesting... I'm assuming the tank fill plumbing is carrying superchilled liquid CH4 and O2, so are these for spinning up engines, or more for things like purging the system prior to launch?
The Nitrogen would be for purging, and the Oxygen and Methane may be for tank pressurization prior to launch (autogenous pressurization requires running engines). To get engine restarts (e.g. boostback, on-orbit, etc), they use helium-pressurized header tanks. Those tanks have a much smaller void to pressurize, so a relatively small amount of helium is needed. Once the engines are started, they can provide autogenous pressurization of the main tanks.
Reactions: scaesare
Yes, the concrete covered berm that was between the sub-orbital pads and their tank farm is being/or has been demolished. I thought SpaceX might keep it as a barrier between the new OLM and its tank farm… but nope.
Reactions: JB47394
New ars Technica article about SpaceX plans in Florida included this bit about Starbase Texas:
"This is now going to be a permanent location for us to be producing and launching vehicles," said Kathy Lueders, SpaceX's general manager at Starbase, in a talk earlier this week. SpaceX is also putting in an office building for SpaceX employees at Starbase.
"Then, we'll probably be in the process of building another high bay," she said. "We are building a second pad right now, too. All of this is to get us ready to be able to start meeting the production and launch rate that we need to be able to accomplish our missions."
Reactions: JB47394
NSF used FAA documents to figure out that the marked rectangular area is the site of the second launch tower (the document just gives a point location). You can see the remains of suborbital pad B just to the right (a ring of concrete supports), and the dirt strip between the two areas that used to be a concrete-covered berm. There's a transport ring roughly in the location of suborbital pad A.
Thanks for posting that image. There was some discussion on the stream today about whether a second tank farm and water deluge system would be built or if the existing GSE would also support the second tower. My guess is that a second farm and deluge system will be constructed, partly because it seems additional areas are being prepared next to the new tower site.
Here's a current photo of the launch site to see the size of the current tank farm and the area available for a new one. They won't have any problems putting in a new tank farm, especially when we subtract the space used by the remaining vertical tanks from the current farm.
The NSF guys were suggesting that the area at the far left was for staging of equipment. That might be the temporary use, but I assume it's going to be concreted over and put to good use.
It'll be interesting to see what they choose to do when designing a new tank farm from scratch after the experience of building and operating the first one.
Just to throw it in here, this is a map showing the supposed boundaries of the SpaceX property at the launch site. It's much larger than I thought. Notice how the developed area in purple has expanded right up to the green shaded area marked as "high marsh area" in the middle, that the little sliver of marsh on the far left was only recently incorporated into the developed area, while the whole area at the upper left has been developed right to the limit of SpaceX's property.
Here's a short video of the test. There's some dark smoke at the end, and I find that a little disconcerting. I wonder if the concrete of the flame trench outlet eroded.
Hmm... kinda seems odd for concrete to produce black smoke like that (but unsure)... I believe they have a new water-cooled flame trench setup there:
I wonder if the black smoke was related to any of that manifold structure....
Reactions: JB47394
The new static fire installation at the Massey's site exhausts across the Rio Grande river into Mexico. I thought this was really odd, but it looks like somebody is sorting that out. RGV Aerial Photography has an image showing that a large square plot of land on the Mexico side has been marked off by a wide cleared border. RGV speculates that it is an 'exclusion zone', which would make sense.
Also, progress on the second launch tower's foundation. They've created a massive grid of rebar. The block of concrete being put in place looks to be about three meters thick, and it rests on a dense array of concrete piles.
Current state of the second launch tower foundations. These are apparently steel "embeds", which are placed down, with concrete poured over them so that they are firmly set into the concrete. RGV says that instead of cladding a concrete structure (the current tower design), they're going to create a steel box and then fill it with concrete.
Reactions: ecarfan
