They are two completely different systems.are the Flex Z struts inferior to the Endurapro? It seems like worth the few hundred dollars more than Endurapro plus lowering springs to get the adjustability.
Are you looking for height or dampening adjustability? The EnduraPro Plus does not have height adjustment option, but if you want a budget-friendly kit with both height and dampening adjustments, look into the ST Suspensions kit which is a much better buy than the FlexZ.
![europeanautosource.com](http://europeanautosource.com/cdn/shop/files/53087293774_5927740a79_b_1200x1200.jpg?v=1690925956)
ST Suspensions - ST XA Coilover Kit - Tesla Model Y
For all those who want to influence more than just their ride height. ST XA Coilovers deliver the look you need through a wide range of height adjustment. With an extensively adjustable damper setup, you can precisely adjust the driving behavior of your car to achieve enhanced road control...
For those looking for more performance, the kits only get better (and unfortunately, more expensive) from there.
