I don't have a service center close to me so taking it to Tesla isn't really an option. I noticed the other day that the toe alignment of the front tires is completely off as the inside of my tires are practically bald while remaining part of the tire is still in good condition. So I went to a local tire shop and had the front tires replaced and a four wheel alignment completed. They fixed the toe issue however they were not able to fix the front camber issue as shims were need to bring the camber into tolerance.
The tire place has been trying to obtain the shims from Tesla, unsurprising to no luck. Does any know if the shims need to be Tesla specific or if any shim kit will work? Has anyone obtained a shim kit from Tesla? I 'm considering calling Tesla directly to obtain the parts needed.
I'm disappointed that the alignment from the factory is so bad that it chewed up two tires and that a local tire place cannot even complete a proper alignment without having to order parts from Tesla.
