12Pack
Unfortunately going back to the previous part of the discussion - those plots however they were generated - do not reflect the real world experience of several (I count at least 3 separate contributors) non-P MS owners.I don’t see that from that acceleration plot. It looks like full torque is available at very low speeds. Also, it takes the same amount of torque to skid the tires no matter what the speed. Torque just translates to force at the point where the tire touches the road.
I will re-iterate - my previous non-P MS85 did NOT experience full, linear acceleration from standstill when you stomped on the throttle, but it ramped up in a non-linear way as if there was a bit of "turbo-lag". My current P100D explodes off the line with immediate acceleration (I'm sure the AWD helps, but so does the immediate power delivery).
If this is the same situation on the M3, then it could be down to the PEM not making the theoretical torque immediately available - allowing the car to get off the line without wheelspin.
