You have to look at total driverless miles and severity of accidents too. Just posting total number of accidents is meaningless because it lacks context.
I mean, I agree...but there's zero context even with the reports.
Let's take a look at the latest report from Waymo for example:
The Waymo AV was traveling northbound on Bayshore Boulevard. As the SUV was passing the Waymo AV to the left, it initiated a right lane change. The front of the SUV made contact with the rear of the Waymo AV. At the time of the impact, the Waymo AV’s Level 4 ADS was engaged in autonomous mode. Both vehicles sustained damage, and the SUV left the scene without exchanging information.
Is all we have, aside from the following facts distinguished by check marks:
Clear, Daylight, Dry, No Unusual Conditions, (Waymo) Proceeding Straight, (Car that caused it) Changing Lanes, Side Swipe.
Cool, but what led to this, what was exactly going on in the situation?
Did the Waymo stop for an unknown reason to the driver, so they went to drive around it and the Waymo started driving while they were doing this?
Was the Waymo vehicle following the speed limit (or driving under it), even though the speed of traffic was higher (causing road rage).
There are plenty of questions I could throw together for any of the reports that aren't answered but could make it a different case. I would honestly be shocked if these reports don't go through a PR cycle before they are submitted to make sure the language is as good for Waymo as possible.
Let's look at another one where it 100% is PR speak.
The Waymo AV was parallel parked along the curb on eastbound Harrison Street at 2nd Street when it began to pull away from the curb and into traffic. As the Waymo AV pulled away from the curb, a pickup truck that was traveling behind the Waymo AV then made contact with the rear of the Waymo AV. At the time of the impact, the Waymo AV’s Level 4 ADS was engaged in autonomous mode, and a test driver was present (in the driver’s seating position). Both vehicles sustained damage.
Aka: The Waymo pulled out in front of a car, causing the car to rear end the Waymo. But it's clearly worded to blame the other driver... "truck that was traveling behind the Waymo AV" vs "car we pulled out in front of"
We also really have no report on the severity of injury from the collisions. I searched all the reports from Waymo in 2023, and only found
one reference to injuries, and it's literally worded as "A passenger in the Waymo AV reported injuries".
Now to highlight some reports I read checking for the injury info.
Waymo hit's a parked car:
https://www.dmv.ca.gov/portal/file/waymo_050623-pdf/
That dog everyone knows about:
https://www.dmv.ca.gov/portal/file/waymo_052123-pdf/
Waymo crowds out someone trying to parallel park, tries to recover then just stops in the path of them backing up (and gets hit):
https://www.dmv.ca.gov/portal/file/waymo_042823-pdf/
Pothole pops a tire (lol):
https://www.dmv.ca.gov/portal/file/waymo_032023_2-pdf/
Waymo on the freeway hits tire scraps:
https://www.dmv.ca.gov/portal/file/waymo_031623_1-pdf/
Waymo get's clotheslined by a chain:
https://www.dmv.ca.gov/portal/file/waymo_030123-pdf/
Hitting cardboard has to be reported, apparently:
https://www.dmv.ca.gov/portal/file/waymo_021523-pdf/
