2024 Model 3 ambient light alignment
Has anyone tweaked the alignment of their 2024 model 3 doors to fix a mis-aligned ambient light strip? Mine is very slightly off on both sides, the passenger side having a pretty sizable gap as well, and I'd like to fix it if I can.
Have you had any luck getting this fixed? Took mine into a service center and they said it’s within spec and that other M3s have the same gap so they’re not fixing it. Horrible design/quality control if you ask me!
They said they couldn't fix mine and might just get worst if they try to.
I tried to see if I can fix it but after removind the door panel/card, there's no way to fix it unless i put a washer on the upper hinge of the door to push the door out a bit. I don't wanna do that though so Ill live with it.
Not to mention, areas on my front bumper that were under sprayed
Reactions: Adam3
Mine are off pretty badly. Took in and they said the same "within spec" nonsense. I have since received a message from the manager of my local spot asking me to bring it back and let them try again. Will report back next week.
cross posting my results. All fixed and wonderful
Reactions: anonimuz
I will definitely make an appointment again! Where are you located?1
