LD rebuild update
Primary shaft bearings (6207/6208)
- 6207 is the counter bore bearing on inverter side of gearbox half
- 6208 is the bearing on the primary shaft pressed in and locked down by a lock nut.
My 6207 was stuck in the bore.
@asavage was kind enough to make a slide hammer puller tip cut out of unistrut piece. Bearing sit raised about 1/4" above the bottom of the bore so tool's lip can get under the bearing with ease. Just went around ID circumference with slide hammer and came out. Wasn't too hard. The reason it was stuck is because the outer race has surface damage where it mates with the bore. Don't know why. Could be there on the rebuild, could be the bearing slipped in the bore? Don't know. New 6207 drops right into the bore at room temp.
@asavage suggest to use locktite retaining compound installing the new bearing. Will update later.
Can also purchase blind bearing puller set but need one with a 35mm collet. Amazon has cheap set for $50+. Probably work fine as 6207 normally comes out by hand if didn't have the race damage like mine. I purchased a motion pro 35mm collet. Unfortunately it uses custom slide hammer threads.
Here is the pic of the slide hammer puller and damaged bearing outer race under microscope.
View attachment 865253View attachment 865254
Changing 6208 is much more challenging for newbie to pulling/mounting bearings (like me! haha)
First remove the locknut and mine had red lock-tite applied. The locknut dimensions is exact (maybe 1mm thinner?) SKF lock nut. Luckily for me again, tool loving
@asavage ordered a SKF socket (none of local auto store spindle sockets fit, close but no fit) and impact gun took the nut off easily just holding the shaft in hand.
Tesla Large Drive Unit (LDU) Motor Teardown and maintenance - Page 10 - openinverter forum
SKF socket is $100. SKF also has a hook spanner wrench for ~$25 (HN7
Hook spanners HN series | SKF) so might consider ordering that along with the SKF bearings. However, probably need a good vice to clamp down the shaft and maybe a cheater bar to remove with hook spanner.
Finally, some people clamp down the shaft and tap the nut loose via the notches. Again, would need a heavy duty vice. Normal right hand threads.
Pulled the bearing with a bearing splitter/puller. Clean off all remaining lock-tite on the lock-nut threads (I actually didn't do until after mounting the new bearing, mistake... read below)
Hammered the new bearing in via inner race with a 1-5/8 12pt socket. But realized afterwards the bearing puller could have been setup to press in the bearing. A couple of notes
- Its an open cage bearing so all the debris can drop into the bearing causing roughness (happened to me). Probably would have been a good idea to tape up the bearing opening facing upwards. Have all lock-tite cleaned off before installing (I didn't) and tape the locknut threads (1-5/8 socket chipped a couple of spots) All this junk went into the new bearing. Took me a awhile with compressed air to get it all out and bearing spinning smooth again. When peeling off the protection, probably turn it upside down so all debris drops to floor rather than into the bearing. Probably won't be able to see the debris but if it goes inside the bearing, you surely can feel it. Here is a pic of the slight thread damage from the 12pt socket. Perhaps 1.5" galvanized pipe (~42mm ID, 6208 ID is 40mm) would have been better (get one cut without the sharp threaded end)
View attachment 865266View attachment 865269View attachment 865271
For those with machine shop skills, probably not too challenging. For a bearing newbie like me... quite the task. Perhaps worth doing some kind for mail-in service for the LDU rebuild community in the future (ship the shaft, get it back with new bearing, maybe additional kit/parts) if I can get comfortable with USPS not losing the shaft! Probably can't easily replace it.
Axle Seal
These hammered out easily and back in using a rubber mallet with the 2 cheap 2"x1-1/2" PVC pipe adapters shown above. Took the inverter (and 2 temp sensor) off to prepare for slide hammering out the stuck 6207 bearing above. Probably didn't need to as it came out with ease.
Gearbox Seal
Ordered 3 Ceimin gearbox seals. 1 was defective but came with nice QC paper work for show. Ceimin seal looks like a good attempt at copying Tesla's seal. Unlikely OEM. Decided to just keep my 32k mile reman gearbox seal. Presumably it was replaced during reman.
Wiped off grease/mud inside of seal lips which seems be in wavy pattern. My gearbox has metallic mud so perhaps these were magnetic field lines from the AC motor?
Coolant Seal Shaft Surface Prep
Followed Johan's 600 grit -> 1500 grit sanding process.
- Shaft had white cloudy layer just outside of the single lip seal mating region (maybe oxidized coolant particulates?). Wouldn't come off with acetone. 600 grit took it off quickly.
- 600 grit sand paper likes to run axially on the shaft so good to have 2 people (1 to spin rotor, 1 to hold sand paper firmly with both hands)
- The lines made by original seal lip will not be completely removed. Likely too deep and require removing quite a bit of material. This line from the original single lip seal will be under the middle lip of a triple lip seal.
- Decided to sand the whole shaft where triple lip seal will sit as resurfacing the white debris and original seal surface is already about 1/2 of the surface area.
- As for how long to sand, not sure there is a right answer. I probably did 1min total on 600 grit and 1min total on 1500. 600 will already make shaft quite shiny and 1500 won't have any visible difference. So really can only go by timing on 1500 grit.
View attachment 865280View attachment 865288View attachment 865282
Hopefully this prep won't leak with the Ceimin triple lip PTFE seal. We shall see...
Rotor and Stator Flash Rusts
Mine had some rusts from the coolant leak. During the clean up, a protective coating is easily removed and get flash rusting. Used acetone on the rotor and got flash rust afterwards. Used denatured alcohol on parts of stator and got flash rust afterwards. Anyway, might apply a light coat of oil or WD40 after cleaning up the surfaces. If no rust to deal with, perhaps just air blow out any dust.
Thought about coating it with light spray of high temp clear coat but don't really know if its a good idea. Probably want to avoid unbalancing the rotor.
