Vendor eas | Southern California Tesla tuning source and daily showroom
Koni Yellows are officially inbound, should have them in a couple of days. Order now to reserve a set!
Reactions: hyp36rmax
Sun's Model Y back for more - this time R1 Concept Brake Rotors & Pads
Coming up to 40K on my MYP and have been noticing the steering has been a bit loose during heavy braking and acceleration. Figured it was a good time to upgrade the notorious Lower Control Arm Bearings, which isn't a matter of "if", but a matter of "when" they will fail usually within 20-30K driving on Model 3, and especially on a heavier platform like the Model Y.
After a surprise visit from @MountainPass while in town during the last Grid Life event, I opted for a set of Mountain Pass Performance Solid Front Lower Control Arm Bearings, and a their Aluminum “Smash Me” Front Skid Plate for good measure. Shortly after installation, it really feels like new again - the steering "wiggle" is gone and wheel feels nice and tight - it feels like again when it was new. These bearings are essential for those wanting a crisp-like feel at the wheel.
MPP's Aluminum Smash Me Plate is a very nice piece, the stock plastic panel was getting beat up and replacement was just about the same cost, making this a real no-brainer. The included Stainless hardware is a really nice touch, as details do matter.
@hyp36rmax back for Round 2 (or is it Round 3?) of mods:
Brembo 6-Pot Caliper Conversion w/ Gyrodisc 370mm 2-piece Rotors
Stainless Brake Lines
Motul RBF600 Brake Fluid
Mountain Pass Performance Cyber Rear Traction Arms
Mountain Pass Performance Arastradero Rear Toe Arms
The Mountain Pass Performance Cyber Rear Trailing Arms didn't make it in time for installation, but will be installing on Friday. Redwood Motorsports Swaybars and Endlinks to follow also!
HPS
HPS Performance Products is a leading manufacturer of engineered joining solutions. HPS currently serves the aerospace, automotive, construction, marine, high performance racing vehicles, commercial truck and bus, agricultural and off highway vehicles, turbo diesel, off-road, truck, food and beverage, general manufacturing industries and water treatment industries. HPS Silicone Hoses also supplies many well-known international firms and our silicone hoses meet or exceed SAEJ20 standards. The ability for HPS to manufacture custom shaped, multiply silicone hoses make it ideal for a wide range of applications. The multiply carcass makes our hose ideal for coolant and turbocharged pressure applications while the fluoro silicone- lined hoses make it safe to be used with petroleum based fuel and oil.
HPS Performance Products continues to meet the original goals of quality products, competitive pricing, and personal, timely response to customers’ needs. Our expertise in silicone hoses allow us to deliver standard sizes silicone hoses with same day shipping; HPS highly skilled and knowledgeable staff, paired with state-of-the-art technology, ensures HPS’s continued success as a premier manufacturer in the industry.
HPS Aluminum Undertray Skid Plates, they're made here in the good 'ol USA and have Plates for both Front and Rear in black finish:
Features
  • Available for both Front and Rear locations for ultimate protection
  • Protect the life line of your Tesla from coolant lines to high voltage cables
  • Drive worry-free with a 2 year limited warranty included with each skid plate
  • Precision cut from 1/8" thick 5052 Aluminum
  • Stainless Steel Hardware is included
  • Direct bolt-on installation
  • Reduced drag coefficient compared to OEM
  • Made in the USA
Reactions: Du30
We just got our stocking order of the HPS Aluminum Undertray Skid Plates, they're made here in SoCal and have Plates for both Front and Rear in black finish:
Features
  • Made in the USA
Since you're local, drop by and check them out in person. If you decide to pull the trigger - we can install for you.
HM? including install
ST Suspensions
For all those who want to influence more than just their ride height. ST XA Coilovers deliver the look you need through a wide range of height adjustment. With an extensively adjustable damper setup, you can precisely adjust the driving behavior of your car to achieve enhanced road control without a compromise in comfort.
EAS is an authorized KW & ST Suspensions dealer - ready to ship immediately or install at our 8000sq ft facility in Anaheim, CA.
XA - More than just lowering
Features
  • Front Lowering: 1.0" to 2.0"
  • Rear Lowering: 1.0" to 2.0"
  • 18 Distinct clicks of Adjustable Rebound Damping
  • Individual lowering within the tested adjustment range
  • Front and rear axle thread adjustment (when possible)
  • Galvanized coilover struts with additional coating for optimized corrosion protection
  • Complete solution with adjustable spring perch, multi-coated spring system and dynamic elastomer bump stops with dust protection
  • Powerful twin-tube dampers with high-quality components for maximum longevity
  • Backed by ST suspension's 5 Year Unlimited Mileage Warranty
Individually Height Adjustable
ST XA Coilover kits deliver precise adjustment to your ride height and look of your car. We manufacture the adjustable spring perch made of durable and friction-optimized polyamide composite material with a stainless steel insert. Thanks to the composite material corrosion is prevented between the strut and perch ensuring long lasting height adjustability while the stainless steel insert provides strength and confidence!
Control The Details
More control of the driving dynamics thanks to adjustable KW rebound technology. ST XA Coilovers come preset to our factory recommended damper settings, the same configuration we test them at on our KW shock dynos before they go into your box. The 18 distinct clicks of adjustable rebound damping allow you to refine the driving dynamics with a simple turn of the adjustment knob. Each kit includes a detailed damper setup manual making it easy to reset to our recommended setting at any time. Whether your preference is comfort, sportiness, or something in between; ST XA puts the finer details of the driving dynamics in your hands.
Closed Rebound Stage - Sporty, tight and maximized performance
Turning the adjustment knob to the right, you increase the rebound force and achieve tighter handling. High rebound forces (closed rebound) improve the handling response, this is especially noticeable on the front axle; the response is a direct and unadulterated sporty experience. This closed rebound stage is ideal if you enjoy spirited drives, long curved banks, canyon carving, and more.
Characteristics at a closed rebound stage:
  • More direct steering
  • Improved handling
  • Pitch and roll movements of body are greatly reduced
Opened Rebound Stage - Retained comfort with added sportiness
Turning the adjustment knob to the left your ST Coilover suspension will provide a much smoother ride and improved ride comfort compared to standard shocks and lowering springs. This is ideal when driving on uneven and rough roads by helping to absorb road frequencies. The opened rebound stage takes ride comfort to the next level.
Characteristics at opened rebound stage:
  • Increased rolling comfort
  • More driving comfort
Galvanized steel struts, low friction materials with layers of protection
Galvanized zinc coated steel struts optimize corrosion protection for long lasting use. We add a dust protection system to prevent unwanted dirt and particulate from coming in contact with the hardened chrome piston rod or getting into the valve packs. We reinforce the system with a multi-layered pressure resistant sealing package, mono block guide system and a low friction piston band which works inside the pressure resistant internal damper housing.
Unique Features
The high quality ST XTA Coilovers have numerous unique features that provide unparalleled value and a long lasting durability.
  • Composite Spring Perches
  • Two-Piece Racing Spring System
  • Dust Protection and Weather-Resistant
KW Quality – exclusively for ST suspensions
The ST suspensions coilovers benefit from our many years of experience in the development and production of suspension components for motorsport and the street. Each damper is hand assembled specifically for your order and put through rigorous quality control testing before being placed in your box for delivery.
Reactions: Du30
Tom
Today, I saw a Tesla M3 that was really lowered (I thought too much so but hey, I have teeth on the front of my car. Everyone's different). I stopped him and we talked. He told me every car he has seen with lowering springs only made the car look like the back end of the car was lower than the front.
He only installs Coilovers on his cars so they can be adjusted so as not to look lower in the back. He told me he actually installed the Coilovers on his M3 himself. I was impressed.
When you install your springs, do they make the car look lower in the rear vs the front and not horizontal?
I wish I could have you do Coilovers but because of my situation, I just don't have the time it takes to have you do the job.
Jim Shaw
Tom
Jim Shaw
Sounds like nothing other than a strong opinion. Which he's entitled to.
Plenty of springs out there sitting evenly, there are a number of examples in this thread. I prefer the coilover route as the suspension components on the Model 3/Model Y leave a lot to be desired, but there's no hard in running springs only.
ST Suspensions has just cut pricing all across the board on their ST XA Coilover kits, making it one of the most competitively priced kits on the market!
Features
Control The Details
  • Improved handling
Unique Features
can you also customize the color of the springs like on their website or just the standard yellow?
You mentioned about 4 hours to install springs only. How many to install Coilovers?
Moving over to a new suspension setup, to the Redwoods are off.
Redwood Motorsports Ohlins DFV Coilovers for Tesla Model Y - Performance Sport
Used for ~25Kmi, no leaks or external damage. Comes with everything seen in images. Didn't have time to clean before taking pictures, but will look fantastic with a quick wipe down. Ready to ship, no waiting. Priced to sell at $2250 shipped US48. Installation available at additional cost to those local to our shop in Anaheim, CA.
Full specs can be found on Redwood Motorsports' website.
PM for quickest reply.
