I regret my Model Y purchase because of seat comfort and seating position problems
I think the design is defective. Worst driver seat I've ever driven.
I don’t think “defective” means what you’re implying in this case.
Comfort is 100% subjective and there’s literally no way to please everyone so compromise has to be made. Like you I’m a bit of an outlier in terms of size at 6’ 5” and 215 pounds so I’m very careful and deliberate about testing out car seats and other stuff like that because the fact is they typically weren’t made with me front of mind. Some I can make work well, others are a no-go.
But at the end of the day “this seat is uncomfortable for me” is not automatically a defect.
I’m 6’4”, 320#, 34” inseam. Today I spent 3+ hours in the 2024 MYLR. The seat was ok, not perfect but not offensive, no pain or discomfort at the end of the day. I could see wanting to add a pad or something on the bottom of the seat to boost me up off the side rails a little as the foam breaks in, but compared to my wife’s Tacoma I think it’s significantly better. The seat is high and the driving position puts my legs in a good position.
We are taking the Y from Cape Cod to Long Island, NY later this week. I’m guessing I’ll have formed some strong opinions one way or another by the time we get home.
We have 2 2023 Model Ys. Only differences are my wife’s is an Austin built with 19” Gemini wheels. Mine is a Freemont built with 20” wheels. I can’t find a way to match the seating positions on both cars. I’m the most comfortable in mine but I can’t get comfortable in my wife’s. It seems like I sit higher in hers no matter where I position the seat. Plus the side bolsters on both push against my hips almost like I have my wallet in my back pocket, which I don’t. Maybe my butt is too wide for the seats. I’m 6’ 245 lbs with a 42” belt size. Not a small guy.
Same i am a bit lighter and also a Fremont Y, I always take my wallet out of my right pocket or I am in pain.
Without the wallet these are my favorite seats other than my 2nd gen Trans Am
The seats have only gotten more comfortable after a year of use.
Arm position in relation to the door armrest and the window also needs to be considered. Steering wheel height might be a problem?
good point....I find the seats are not as comfortable as mu Model S....understand that seats are very different.....MS they are longer and wider....The MY seems to be shorter and not as wide....that being said, I have to sit a little toward the center console....Just my body position....but I did notice that when I am sitting in the exact middle of the seat, the steering wheel is about 2-3 inches left of center......in order for my body to be centered on the wheel, I have to physically move left and I find I am almost sitting on the left bolster.....I thought I was crazy until my wife looked at me and saw the same thing.....then she sat in the drivers seat and she experienced the same....The center of the wheel was 2-3 inches to the left...but if she moved her body to the left to center the wheel, she too, was sitting on the bolster......Tomorrow I will go visit my friendly and supportive service center and see what they have to say......probably get the old, "well, it is like in each car and is normal or I can see or feel any thing wrong"...we'll see
I just got my 24 Tesla Y - love the car - HATE the driver seat. When I drive I get stiff neck, shoulders and sore back. 6'2" and 240lbs the lumbar support is too low. no upper back support and the non-adjustable head rest pushes my head uncomfortable forward. I've never had a problem like this in other cards I've driven. I think I need to give my car back to Tesla. Not sure show long I can stand this. Anyone else have this problem? Any solutions?
It took me weeks to figure out I had an issue with the driver's seat after purchase. And another few weeks of mucking around trying different things until I managed to get myself to a happy place. That said, I did a minor modification to the bottom seat cushion and if you're desperate, handy, and want to try something fairly low cost and non-invasive (easy to reverse) check this out and see if it's worth trying for you.
Uncomfortable Front Seat(s) / Thigh Bolster Mod
Scroll through the thread from there where I gave someone the dimensions I used and tried to explain how I installed it.
I'm not saying it's a smoking gun or will work for everyone, but it saved me. Still not the most comfortable seat I've ever had but its totally manageable now - again, for me. I have had days where I've been in the car for 4-5 hrs total and single trips of 2.5-3 hrs and felt fine vs being sore and uncomfortable after 20 minutes in the seat before.
That said, my issues were primarily in my hips and my legs and not my back. So it may not help, but the pad effectively lifts the bottom of the chair a bit, and may help fix hip position, and thus may help the back posture.
Also, you may not be used to the somewhat forward leaning headrest (vs other cars I've had) yet. That may be contributing to neck / shoulder discomfort if you're leaning forward and don't realize it. Try tilting your backrest back a bit so your head and neck are vertical with your shoulders when relaxed (vs hanging in front of them). Doesn't have to be a lot further back, may just be a tap or 2 of the recline button. I did this and it also helped. After doing this I also had to slide the seat bottom forward a bit to keep arm length to wheel and controls after doing so because of my short t-rex arms.
Just trying to help you through the journey I took. After getting the bottom pad in I was able to dial in the seat better with only minor temporary tweaks needed from time to time. I'm at 1 yr ownership and about to hit 30k kms and the above made the difference between me approaching the thoughts of ditching a brand new car and being happy with it as a daily driver. I initially intended to take it out after installing it like that to try a second layer of the softer foam on top but I never did for fear of going backwards in comfort.
Before I got my YLR I'd been driving the same car for almost 12 years. At first I thought I'd never be comfortable in the Y, but after a few weeks I started to get used to it and now I'm just as comfortable in the Y as I was in my old car. I purposefully didn't fiddle with the seat settings every time I got in the car, and I guess my body just got used to the different seat. We've done several multi-hour road trips with the Y and I find it nice and comfortable now.
The one thing I learned was to never mess with the lumbar support, the damn thing has a mind of its own and isn't saved as part of the seat memory settings.
We shouldn't have to 'rebuild' a seat on a new $50-60k car. 2000 miles on my '24 Y and I'm not sure I can live with this car solely due to the seat. Everyday I drive, I'm experience neck, back and shoulder pain. most seats of any car I've ever owned (I'm 58). 6'2" 240 lbs
I agree with your sentiment. I've never had such pain in any car I've ever owned since 1966!!!! And never have I been in so much pain while riding in anyone else's vehicle.
But I've already made my Tesla M3P to my liking, so in my case I'm keeping it.
Interesting. Sorry about your discomfort.
I"m the exact opposite. I've owned various cars since 1970, and I find the MYLR seat so comfortable that I actually look forward to midday power-naps, and the power-naps I take while road tripping.
Now at 54k miles, I couldn't be happier with the comfort of the seats.
YMMV.
6’4” and 320#, I put 260 miles on my Y yesterday. The bottom of the seat was fine, the bolsters felt narrow an hour into the trip. The car only has 1100 miles on it, so there is certainly some opportunity for break in on the bolster foams. I may take a rolling pin and see if I can accelerate the process.
A quick search turned up this guide for seat disassembly. I wonder if the metal frame of the seat could be modified to relax the side bolsters. Modifying the foam would be much easier.
Sooo how did it go? :)
Thank you for this! I did the same thing yesterday after buying the stuff and first quick drive, seems to have made a big difference! I still have to reclip all the stuff under the seat but my hand strength was gone lol. Today is another day!
Check eBay for wrecked Model 3 Highland seats. They're bigger and more comfortable. Will *probably* bolt in? But who knows on the electronics-side if they'll match up. I would love to be the first one to try this mod someday if it isn't $1000+++
Based on the variety of opinions that Tesla MY seats are uncomfortable, it's probably dangerous to assume that the Highland seats are "...more comfortable..." for everyone.
YMMV. :D
YMMV. :D
Agreed - but I'm in the "MY seats are uncomfortable" camp and sat in a new Model 3 and thought they were much improved. Less curvy on the back, wider bolsters, and better shoulder support. They're noticeably bigger, like most cars sold in the US now.
The Highland seats aren't amazing by any means, any BMW or Volvo seat will blow them out of the water, but they're better.
YMMV.
The best I can figure it's a different experience due to differences in body build, mostly bone structure.
Mostly, but not all the pained drivers are somewhat larger than average.
For my slightly larger than average hip bones, too wide for the metal seat frame.
I have a frame and took it apart to examine.
Many owners have reached out to me.
I increased the foam base so that my hips had room they needed and the pain ended.
Just another data point but our other car is a BMW and everyone in my family thinks the Model Y seats are more comfortable…
just as I thought.....this is the way the car is manufactured...have not had any other complaints......just used to the Model S I guess....but, this Y is a nice car and very efficient......cant wait for the matrix headlights to be turned on....they have been under latest V12 release....just waiting for my turn as I am on 2014.3.25
For the OP if still around. I hope it got worked out. Something it looked like you missed is the adjustment of the steering wheel.
I need to stretch my legs out due to injury making me too far from most steering wheels. The in out is a godsend. It may straighten me back out from decades of hunching forward.
In your case wheel full in to the dash and seat forward I would have thought should work, along with a centre back of seat padding addition to get you off the side bolters in the seat.
For me, can't figure how to get it to save my seat position. It saved the wheel but not the seat. Doesn't seem to be editable. Very strange.
