Roadster 2.5 double DIN radio options
dsm363
Roadster + Sig Model S
Moderator
May 17, 2009
19,179
934
Nevada
Does anyone have a good option for replacement on the original radio? I would like something that you can display your speed on as it’s hard to see the speedometer if you’re taller. Thanks.
You may want to check out this thread. While I don't recall mine doing speed, it was a good setup. I've since parted with the car to @Retiredeh, so don't know how the stereo install is holding up. Alpine ILX-207. I also considered the Alpine ILX-650, which also fits. Instead of the Alpine amp, I had a bit higher-powered amp put in, the Rockford Fosgate Power T1000X5ad recommended by @CM_007's son Randy.
