Another interesting note is the "new" J3400/NACS standard standard has allowed for 277v single phase, ie, Phase-to-Neutral in common 3ph commercial settings in the USA. which means its easier to manage as there are no step down transformers required to pull the voltage back to 220v. This will make it cheaper to install high volume AC charging in commercial sites.
Still think whilst NACS is great, they stuffed the original design by not adding 2 more pins for three phase support that would only result in a slightly larger size, it could them have been a true world standard.
And just to bang on the same point, type 2 is decent connector, and unless you are fast charging often, there is nothing bulky or difficult to use about Type 2. And even in the CCS2 setting, Tesla has again set the standard in making to connector much more user friendly than the other brands like Phoenix Contact.
