wwhitney
A few point to consider:PS: I just picked up the lumber from Home Depot an hour ago, and ready to put this thing together!
Untreated wood should not bear directly on concrete. Use treated lumber on the concrete, or a barrier like galvanized sheet metal.
Green wood will shrink significantly perpendicular to the grain as it dries. Treated wood is typically sold very wet and will shrink even more than green wood.
The wallward-most Powerwall will be mounted to the wall, while the other two will be resting on the platform, and just attached to the previous Powerwall for lateral support. So if your platform shrinks in height, the front two will drop, and the connection between the middle one and the rearmost one will be stressed.
If you are going to use solid-sawn wood, ensuring that the height of your platform depends on members with the grain running vertically will reduce these effects significantly. Wood does shrink longitudinally as it dries, but the shrinkage is at least an order of magnitude less.
Cheers,
Wayne
