So, if my single is 6" to the outer side, and the double stack is 12.5" off the wall then the separator is about .5"Here is my 2 stack off a concrete wall.
I have a double stack next to a single stack off a concrete wall.
19 is the correct amount. Here is my 3 stack measurements from wall and I also got you the height from the garage floor when it’s sitting on it’s own legs.Perfect! Thank you so much! So based on your info, a stack of 3 should be 12.5 + 6.5 = 19" from the wall, including the hanging bracket for the 1st PW.
I'll do some research into the AC pad idea, but I'm needing the 3 PWs lifted 12 inches, so I'd have to stack them, plus I'd want them cut to the footprint size. Thanks for the idea, and the dimensions of your stacked PWs! Very much appreciate it!
At least in some locations, the power switch has to be located below a certain height. I believe it can't be higher than 7 feet from the floor.What is the reason for the maximum height above the ground to be 1m (39.4 inches) ?
If a PW is mounted on the floor, it would be 45.3 inches (1.15m) tall, plus the recommended 2" (.05m), that would put the bottom of the upper PowerWall at 47.3 inches (1.2m). The top of that PW (including the 2" air gap) would be 94.3 inches (2.4m).
The ceiling in our garage is 136 inches (3.4m), so there's plenty of vertical space on the wall to have 2 vertically stacked PowerWalls (with more than the minimum 2" gap).
Why can't the upper PW be mounted 8" higher than the specified 39.4"?
The only reason I can think of is concern about mounting/dismounting the PowerWall. With a 1m gap underneath, that may be low enough that installers can mount the PowerWall by standing on the floor - and anything higher might require using ladders or a small platform to mount/dismount the PowerWall from the wall bracket.
Will check with our installer about this...
I have only seen floor mounted free standing Powerwalls in Tesla press images. Every real installation I've seen pictures of has them secured to a wall as well as resting on the floor.Has anyone considered the seismic load on these assorted installation arrangements. My concern is for the floor mount units that appear to be unattached to anything.
The vertical stacking is disallowed because the Powerwall attach to a wall system. The wall system is constructed per a typical wall depicted in house plans. The wall structure passes the Uniform Building Code. Now, mate the Powerwall to said wall structure. Now we have a Powerwall installation which had been UL tested and proven (two studs bearing weight of single PW). Simply said the vertical stacking is not tested nor verified. There is one way out which is to engineer a wall structure to accommodate vertical stacking (submit design, get city structural to buy off, build, and inspect). Tesla said this would need to be engineered and will be costly, and would be best to integrate for new home construction, which requires much forward thinking.Additionally, having two 275lbs PWs on the same studs is considered too heavy for some city codes.
Someone said the power switch can't be too high for ADA reasons, but for fire safety reasons also, that upper switch needs to be easily accessible for anyone to shut it off in case of an emergency. Without requiring a stool. Hence the 6" clearance needed to the right of the PW also. I SO wish my installers would install them vertically on top of each other...that would have looked so cool!
They use a metal bracket piece on the back that attaches to a stud,Has anyone considered the seismic load on these assorted installation arrangements. My concern is for the floor mount units that appear to be unattached to anything.
Most any other type of screw would give you a better attachment. Deck screws are readily available and would work. Best would be a few structural screws, something made by GRK, SPAX, Simpson Strongtie or Fastenmaster.Mine will be screwed into the 2x4s in the wall using long drywall type of screws.
Heard back from the installers - the 4 PowerWalls will now be installed on the floor inside the garage, probably in two double-PW stacks - and not attempt vertical stacking.
Oh well - seemed like an interesting idea to save a little floor space...
Those switches can trivially be extended down under six feet. They aren't carrying power leads, just logic leads. If what you said is their actual stated reason, you can easily modify the plans to extend the switch (with engineer approval from Tesla, something I think is possible today; this prediction is only good until December 31, 2019). While not a great curiosity for Tesla, doing so may be mildly curious for their engineers, so they might be willing to specify an extension for that switch. This is especially true right now (and more so in the last two years), so I would expect that curiosity to expire soon, if it hasn't already. But I suspect we will see a recurring theme about this for years to come.Hi bob_p,
Here in the south Bay Area, I was told by our installers/designer that building code will NOT let us put them above the floor-mounted ones. I too wanted that initially but they said the PW's power switch cannot be higher than 6 feet off the ground, for safety/emergency reasons (?!).
