mhan00
Smart summon is separate from Nav on city streets.Any videos of improved smart summon??
Clearly Its over for Waymo, Cruise, Mobileye and Huawei!!New video showing similar left hand turn problems:
Huawei Autopilot which will be released in Q4 on the 2021 Arcfox Alpha S works anywhere in china.
Mobileye's Supervision which will be released on the 2021 Zeekr 001 works anywhere in the world.
They are all doing that without 100k or even 1k cars roaming around. You're simply wrong from every angle. The industry is doing more sim and less real world.
Not the other way around.
Maybe on a geological scale.Sounds like new features are coming "soon":
Interesting. Tesla starting to code in measures to avoid difficult unprotected lefts, maybe, and just not doing it well so far? The ability to re-route on the fly to account for missed turns and unexpected traffic and road conditions is something that will be necessary eventually.#FSDBeta 9.0 - 2021.4.18.12 - Unprotected Left Turns Stuck in a Navigation Loop
I need some more eyes on this to help me understand what is going on. Check it out.
There's no confusion. The problem is you unable to grasp simple simulation concepts. Just weeks ago you were saying data augmentation is the same as simulation.
This is something that you seemingly are unable to grasp. The industry is not going the other way. They are not trying to get more real world data.
The opposite is completely true. They are improving B to the point that they need less A. The more realistic and complex B is, the less A is required and the more they can improve their software exponentially using more B.
You simply can't grasp that, that's why you run around saying " Simulations are not creating weird cases that may only happen in Fargo, South Dakota because Waymo engineers haven't come across those weird cases before." or "simulation doesn't replace real world edge cases".
Sim does exactly that. Not only is the AV industry moving towards more complex and realistic simulation as seen with Waymo's Simulation Cities. The AI industry at large is doing so as well.
Your sim can get so good that you only need a tiny amount of real world data as a bootstrap or none at all.
"Today, a team of researchers from Facebook AI, UC Berkeley, and Carnegie Mellon University’s School of Computer Science are announcing Rapid Motor Adaptation (RMA), a breakthrough in artificial intelligence that enables legged robots to adapt intelligently in real time to challenging, unfamiliar new terrain and circumstances. RMA uses a novel combination of two policies, both learned entirely in simulation"
AI now enables robots to adapt rapidly to changing real world conditions
Researchers from Facebook AI, @berkeley_ai and @SCSatCMU have developed AI that can enable a legged robot or other machines to adapt in fractions of a second to changing conditions in the real world.ai.facebook.com
However, a number of challenges emerge when these skills are first learned in simulation and then deployed in the real world. The physical robot and its model in the simulator are often different in small but important ways. There might be a slight latency between a control signal being sent and the actuator moving, for example, or a scuff on a foot that makes it less slippery than before, or the angle of a joint might be off by a hundredth of a degree.
The physical world itself also presents intricacies that a simulator, which is modeled on rigid bodies moving in free space, cannot accurately capture. Surfaces like a mattress or a mud puddle can deform on contact. An environment that’s fairly standardized in simulation becomes much more varied and complex in the real world, moreso when one factors the multitude of terrains that can exist in both indoor and outdoor spaces. And of course, factors in the real world are never static, so one real-world environment that a legged robot is able to master can be completely different from another.
Looks like Tesla is spending more time on perception tasks than planning tasks right now. Which makes sense, given the removal of radar and reliance on a camera-only solution. Definitely interesting to watch, though!#FSDBeta 9.0 - 2021.4.18.12 - Unprotected Left Turns Stuck in a Navigation Loop
There’s some robotaxi code to get more money from customers#FSDBeta 9.0 - 2021.4.18.12 - Unprotected Left Turns Stuck in a Navigation Loop
Must be confusing for drivers behind you… you’re signaling left but the car keeps going right. A more aggressive driver might go to the right of you for a right turn since your car is signaling its intention to wait for a left turn.#FSDBeta 9.0 - 2021.4.18.12 - Unprotected Left Turns Stuck in a Navigation Loop
It's confusing overall. Why is the signaling module doing something different from the steering module?Must be confusing for drivers behind you… you’re signaling left but the car keeps going right. A more aggressive driver might go to the right of you for a right turn since your car is signaling its intention to wait for a left turn.
Some of these drives are approaching Waymo performance in areas more complicated than Chandler (IMO):
Mobileye is done for, has been since Tesla broke up with them. V9 is so so impressive. Tesla Vision is a software / technical / engineering marvel. I'd even hazard to say that Waymo is done for as well (just watched a Waymo video to balance out my perspective). It's sad that everyone else is pursuing fsd the wrong way, but I totally understand how immensely difficult it'd be to change their approaches.
It looks like their RADAR hardware uses CAN bus (1 Mbps, or *maybe* 10 Mbps). I was assuming it used something much faster, like automotive Ethernet. That design also means Tesla can't ever retrofit LIDAR or 4D RADAR over that connection. *sigh*However, I think a limitation is the number and protocol of sensor connectors in the HW3 computer. IDK but it seems unlikely that the radar data port can be repurposed in-situ for additional camera(s). Possibly a video pre-processor module that blends say the left & right windshield wide-view camera feeds with the new left & right corner camera feeds, so that the stream into the existing camera ports can use it without a complete redo of the FSD hardware configuration.
I feel it's very important that we get a proper Tesla response to this.What....have you watched this? What a joke... A simple unprotected left turn and it fails consistently and tries to cause a dozen accident and head on collisons.
versus v9
You do realize that performance includes safety right?
Here are 122 unprotected left from one rider (@JJRicks wondering when you are going to post the compilation)
JJRicks.com - Videos
Find the full playlist of videos here or at jrj.pw/waymo for quick access.www.jjricks.com
versus v9
If this is the performance of your so-called leader of AV that is supposedly 5-10 years ahead. Then we will never solve AV.
