Help! Paint Damage to Model S
Hi. I wanted to know what options I have to try to alleviate this scratch (see pics) on my Model S (85D) in black. I have tried Mother's Rubbing Compound but it didn't seem to do anything. Is touch-up paint from the tesla shop a good option or is there something better on the market?
This is something I would take to a professional body shop. They have experience and resources that most individuals do not. If this can be buffed out, it seems well worth the reasonable $$$ they would likely charge.
Thanks! The tesla-approved body shop near me is quite expensive. I was hoping for a less expensive option.
You can try the touch up paint. You are probably going to use up the entire bottle, but they are pretty inexpensive.
However, I don't think you'll like the result of the touch up paint. This is a reason why a lot of folks on the board get protective film for the front.. Replacing the film is around $1000 while getting it fixed probably costs several times that.
Thanks for the suggestion. In hindsight i should have used a film.
Similar issue (Less Than 2wks Old And Scratched. What can I do?), so I ordered touch up paint from Tesla. Looked a bit better to an untrained eye. Ended up taking it to the detail department at Tesla where I picked up my car about a week later and the detailer buffed most of it out. He was able to because the paint hadn't really bonded too well yet. Looks much better.
But now I have a deeper scratch on the driver door and the detailer recommended I go to my local body guy, but make sure he uses ddp (?) paint. Not really sure what that is. I haven't got a quote for that yet as I don't think the scratch is too noticeable.
Good luck!
Good luck!
Thanks. I will try the touch up paint and see how it looks. If not better, I will go to body shop. Is that a good idea?
