No, they will not void any warranties becauseMight be a silly q - but does changing the lights, in the cabin or frunk or trunk, somehow jeopardize or void the warranty?
I’m seeing threads that the audio work does seem to be cause 12v battery issues - wondering if its the same with the lights?
Hey There. So, if I’m understanding your comments correctly, your particular kit has the dashboard light strip running where I’ve drawn the yellow line in my photo from below. Correct? If so, that is a location I’ve not seen before. At one point, I did consider running/installing a light strip in this area. However, that thought quickly went away, when I realized it is simply not possible to run & properly/completely conceal a light strip along this part of the dashboard.I'm getting ready to install a light strip across the dash but I've noticed different locations between some of the products.
The one I have depicts an installation across the top of the wood trim and the one in this thread appears to be on a dashboard part above that (closer to the windshield). Then there's the SUMK one that goes even lower near the steering wheel.
What are your thoughts on the various locations for the light strips? Is it purely cosmetic or does one position reflect more/less off the windshield at night?
That is correct.So, if I’m understanding your comments correctly, your particular kit has the dashboard light strip running where I’ve drawn the yellow line in my photo from below. Correct?
I certainly would not recommend running the light tube along this part of the dashboard. But, if you don’t mind having/seeing a short section of exposed light tube at the two ends, then you should be OK. Yes, applying some black shrink tubing will help make the exposed light tube in this area a little less visible, but it will still be exposed/visible (i.e. not hidden behind trim work).That is correct.
I haven't removed the side panel yet, but it seems like the light source could potentially be hidden behind that section. Using the black shrink tubing may also help hide it.
So, in summary, I have the SUMK light strips on mydashboardand the thin acrylic light strips from AliExpress on my dashboard.
Good find! I just ordered a strip for my dashboard. I'm happy with the Nestour stuff everywhere else but the dashboard is really visible so this looks perfect for that.
Semi related. I just built myself a classic arcade machine as a project over Christmas and ordered a cheap light strip kit from AliExpress and put it all around the edges under the T-Molding. I did up some graphics that were Tron based and thought there is no better way to compliment that than some light strips.
Check it out. View attachment 760643View attachment 760644
Every night is game night! Whenever travel goes back to normal and you feel like traveling to the other side of the world.Nice! So, when is game night and what time should I be there?!![]()
Hello, I was just wondering if you know of anyone on the internet that has done a kit such as this or even any kind of install videos? I've been considering one of the Amazon kits like everyone else, but that kit is intriguing and cleaner. And the little extra touches like for the speaker grill. I just don't know if I'd follow through the purchase without seeing how exactly everything gets wired up first and if everything is truly hidden away.These are the more comprehensive light kits sold all over AliExpress, Ebay, etc… which look fantastic and give a very professional looking result. The downside is they also require a lot more dismantling of your interior cabin to install the supplied trim pieces and precut light strips.
639.0US $ 29% OFF|For Tesla Model3 Model 3 2019 2020 2021 Inter Lamp Touch Control Inter Car Ambient Light 128 Colors Center Pillar Horn Cover - Decorative Lamps & Strips - AliExpress
Smarter Shopping, Better Living! Aliexpress.comwww.aliexpress.com
Here’s an instructional video from Hansshow for their ambient light kit. If you search on something like, ”ambient light kit Tesla model 3” on YouTube, you’ll find other install videos. Unfortunately, I doubt any of these videos will provide an easy to follow, complete step-by-step guide. As is the case with most of these products, you’ll probably need to figure certain things out as you go along…Hello, I was just wondering if you know of anyone on the internet that has done a kit such as this or even any kind of install videos? I've been considering one of the Amazon kits like everyone else, but that kit is intriguing and cleaner. And the little extra touches like for the speaker grill. I just don't know if I'd follow through the purchase without seeing how exactly everything gets wired up first and if everything is truly hidden away.
I am going to go ahead and commit to both the SUMK kit as well as the aliexpress fiber as well in a few days.As an update, I believe I have found the perfect light strip for my dashboard (to compliment the console light strips that I am currently using from SUMK). This light strip is from a seller on AliExpress. Link provided below. As mentioned in one of my previous posts, I did not use/install SUMK’s dashboard lights because it is a 2-piece design and simply looks bad.
6.49US $ 35% OFF|Auto Interior Decorative Atmosphere Lamp Acrylic Optic Fiber Lights Rgb Ambient Light Sound Control With 12v Cigarette Lighter - Decorative Lamps & Strips - AliExpress
Below are some photos of this other/new light strip. It is a little thinner than the one from SUMK and a lot thinner than the light tubes supplied by most other manufacturers/light kits out there. As you can see, the design/shape of this light strip is also much different than the others… and that is a good thing especially for the dashboard.
This light strip consists of two parts: 1) an inner tube which is about 1.5 mm in diameter, and 2) a thin flat acrylic strip
The inner tube is attached to the thin flat strip with a silver colored foil/tape. This tape covers the entire inner tube and most of the thin flat strip, except for the edges. So, when this light strip is install in your trim work, it is not the tube that is lit/seen. Instead, what is lit and seen is only the thin edges of this light strip, which I estimate to be about 1 mm in thickness. The second photo below is taken at an angle which shows the edge of the exposed strip. The benefit of this type of design is it produces a much cleaner and more defined light effect. A very ”refined” look, compared to the typical light tube that is used by everyone else.
In my opinion, this light strip is the perfect type to use for the dashboard. As you can see from the additional photos shown below, they look fantastic when on… and are so thin/discreet that they also look great during the day when off. For me, the larger 3 mm diameter round tubes that are used in all the other light kits, can look a little cheesy at times. By contrast, this one looks sleek under all conditions.
So, in summary, I have the SUMK light strips on my dashboard and the thin acrylic light strips from AliExpress on my dashboard.
Final note: For the dashboard, I have light emitters on both ends/sides of the dashboard, so the light output across the entire dashboard is more uniform/consistent.
ON:
OFF:
ON:
OFF:
ON:
OFF:
CONSOLE LIGHTS ON:
CONSOLE LIGHTS OFF:
If you plan on using the SUMK kit for just the console and the AliExpress one for the dashboard, then absolutely no concerns. I believe the refreshed consoles on the 21/22 models have a tighter gap between the trim work, compared to the 20 and older models like mine. Since the light strips from SUMK are thinner than those from most if not all other light tubes/manufacturers, you should actually have an easier time inserting/installing SUMK’s light strip on your particular console (and it will also look a lot better/cleaner once installed IMO).I am going to go ahead and commit to both the SUMK kit as well as the aliexpress fiber as well in a few days.
Unfortunately, the delivery for the aliexpress one is looking like mid to late March, and I couldn't find anything that matches that on other places like Amazon or eBay.
Anything I should be worried about with a 2022 M3?
So, just a heads-up on the SUMK kit. Since they have designed their dashboard light strip to be installed at a lower location on the dashboard and with the two ends terminating on each side of the center display, the cable/wiring that they supply for the two emitters that are intended for their dashboard lights are a little shorter than the cables from most other manufacturers/light kits. This means you will need to cut/splice these two cables and extend them by about 2-3 feet. This extra length will be needed so you can run these two cables/emitters from the cigarette plug all the way to each side of the dashboard. I think it is very easy to do, but understand/appreciate that some may not feel comfortable doing this. Keep in mind that each emitter on the SUMK kit outputs only 0.6 watt, so extremely low power draw (in case you are concerned with creating additional resistance/heat by splicing and adding a little length to these cables). In other words, it’s a complete non-issue as far as additional heat and safety are concerned… assuming you do the splicing correctly.Sounds good, your write up definitely convinced me. I will just run the cables to the dash and wait on the delivery from China. Will definitely buy at least 3 lengths. Do you have any other recommendations? Heat shrinks, adhesives? Thanks in advance.
Also, unrelated, but I'm just going to get an armrest console organizer which can let me hide some of the cable mess as I'm not willing to drill anything just yet. May look into a more stealth installation in future.
