Internal, of course
How about this? Move propellant from the main tanks to the header tanks.But what exactly will a “propellant transfer demonstration” include?
If that is what will happen then SpaceX needs to actually get to orbit instead of "almost orbit?" Unless NASA will consider it a success in an almost orbit situation. One full orbit around the planet before the landing near Hawaii. The reality is that once you're there it isn't much more to get an extra orbit in.How about this? Move propellant from the main tanks to the header tanks.
The idea is that if you fire your engines in microgravity, you need to use the header tanks, which always start full. But if you do that, then turn the engines off again, you have partially-depleted header tanks and you can't relight your engines. So the demonstration could be a way of firing the engines using the header tanks, which seats the propellant in the main tanks, which allows you switch back to the main tanks. Then you stop using the header tanks, pump from the main tanks to the header tanks to top them off again, and you're ready for another microgravity engine restart.
60 minutes of orbiting is long enough to show the transfer works. Risky to rely on a deorbit burn.If that is what will happen then SpaceX needs to actually get to orbit instead of "almost orbit?" Unless NASA will consider it a success in an almost orbit situation. One full orbit around the planet before the landing near Hawaii. The reality is that once you're there it isn't much more to get an extra orbit in.
Well that was unexpected. But what exactly will a “propellant transfer demonstration” include? There will only be one vehicle involved with IFT-3, obviously.
SpaceX is under a lot of pressure from NASA to make progress on the HLS. I hope they are not rushing this “demonstration”. They have yet to get Starship to orbit…
While the booster and Starship are guaranteed losses, they should definitely be trying out the stuff that is most risky to the vehicles. Once they have vehicle landing worked out, they're going to need to have all the risky stuff locked down.They seem to work under the idea that every test flight should end up with something that has maybe only a 50/50 chance of working...each flight practically guarantees they'll learn from a failure. And they make extremely rapid progress as a result.
Internal, of course
An award to SpaceX worth $53.2 million will go toward a “large-scale flight demonstration to transfer 10 metric tons of cryogenic propellant, specifically liquid oxygen, between tanks on a Starship vehicle,” NASA said.
Thanks, that seems pretty clear that the propellant transfer test will be intra-vehicle.transfer 10 metric tons of cryogenic propellant, specifically liquid oxygen, between tanks on a Starship vehicle
Thrust and/ or pump based transfer testing for feasibility and performance. The docking system is a thing, but from a fluids point of view, it's 'just' more plumbing.Thanks, that seems pretty clear that the propellant transfer test will be intra-vehicle.
But what would be learned from a test like that? The objective is a transfer between two Starships that are docked together. Would such a test be about the pump system’s operation in microgravity?
Booster 10 has received a hot staging ring. It looks to be the same design as the last one.
I just want to see the video. Surely they had cameras inside the base of the Starship engine bay to record what happened at hot staging. Maybe there was nothing to see, given all the gasses being thrown around.I kinda feel like the design points most likely to be changed for the HSR's would be (in descending order of likelihood):
Yes..I just want to see the video. Surely they had cameras inside the base of the Starship engine bay to record what happened at hot staging. Maybe there was nothing to see, given all the gasses being thrown around.
In truth, it would be nice if they released any onboard footage.
He may have been preoccupied with the Cybertruck delivery event since the launch. I hear that he has a rather busy life. Or the SpaceX folks are looking over all that wonderful data to understand it themselves. It's only been two and a half weeks.It's rather interesting that at this point we haven't seen any on-board video. Or Elon hasn't tweeted about what failed.
I wish that Elon would focus his addiction for attention on the people who appreciate his statements. He makes social commentary and gets crucified by haters, but if he talks technical, he gets adored by fans. Perhaps his upbringing just pushes him to stoke the haters. If he'd just let us know, I'm sure we could get some technical folks to call him stupid on a regular basis.Maybe they don't know at this point, but I'd be surprised if so... they have to have instrumented the snot out of Starship.
