GWord
But I'm having trouble with the pressure differential part. Rockets are cylinders designed with a high pressure inside. We're proposing burying them with just 1atm inside to keep the pressure out, that there's your differential. But I have no experience or training here to know how difficult a problem that is to solve.
A tremendous amount of civil engineering would go into a final answer, I'm sure. But for the purposes of your thought exercise, I think you can assume the pressure that the Starship hull has to resist to be just the mass of the soil prism over the pipe, times Martian gravity.
This study seems to indicate a depth of around ~5ft (1.5m) into the martial regolith provides adequate shielding against ionizing radiation. Check my math, but I see several studies pegging martian soil density at 1.5 to 2.5 g/cm3. So if I choose 2g/cm3 and multiply by 150cm depth, that's 300g/cm2 (0.3 Bar) of pressure to resist. Obviously to be more accurate one would need integrate the parabola of the hull curve but that doesn't really swing the needle here. And another thing, this doesn't take into account the .38% pull of martian gravity, so it's even less right?
