I see. I thought VG indicated it was reduced but at least it's not plaid mode logging still.
True, but it's still on ludicrous
UH, No.Elon just froze all the MCU1 owners with that tweet. Anyone who had thoughts of trading up for a newer MCU2 car will do nothing now and sit back until he clarifies his tweet.
ramdisk FTW!
That’s great for FSD computer. But that won’t change MCU 1 to MCU 2 as that’s separate :-(
I don't think you'll have to wait that long. I think we'll have an answer sooner than that.I’m hoping by next summer we have a clear answer of upgrading MCU 1 to 2. That’s when I plan on finally bringing in my car for the first time just before my warranty expires. Would like to get it at that time along with the FSD computer.
Oh really??I don't think you'll have to wait that long. I think we'll have an answer sooner than that.
I thought this moved to sd card? Significantly easier to replace than soldered down on mobo...
Because of the IC display, an upgrade could not be simply a reharnassed MCU2.
Who says they aren't going to make replacing the IC part of the retrofit package?
They have to replace the IC if they retrofit. The IC on MCU2 is just monitor with an additional speaker. Where <= MCU1 is an actual computer.
Yeah, it should be possible with the old IC if it they just have the right connection.Seeing as how I don't actually have to do the design work, I'd just put both ports on the MCU2.5; one for an MCU2 style 2nd display and one that's a network port for MCU1 style IC. To save money and ease integration I'd only put actual connectors on one or the other for factory assembly, but for repair parts I'd put both connectors on the board.
Does the MCU1 directly connect to the IC computer, or is it through that central network? If the latter, couldn’t this be handled in software, with a retrofitted MCU2 just sending the same data MCU1 sends?
It not a matter of being able to just physically plug a wire in. There is software/function changes. You talk about connectors like that all that matters is being able to plug it in.Seeing as how I don't actually have to do the design work, I'd just put both ports on the MCU2.5; one for an MCU2 style 2nd display and one that's a network port for MCU1 style IC. To save money and ease integration I'd only put actual connectors on one or the other for factory assembly, but for repair parts I'd put both connectors on the board.
