(1) 18" MODEL 3 OEM Factory Wheel/TPMS/Tire - $175
Selling (1) Model 3 18'' Aero Wheel with tire mounted and balanced, with TPMS, $175.
Wheel itself has curb rash around the perimeter of the rim, most wheel shops will repair it for ~$100 if wanted.
Tire (OEM Michelin Primacy MXM4, 235/45/18) has ~2000 miles on it, essentially brand new, no punctures, never repaired.
Perfect for as a full sized spare.
Wheel Specs:
MFG Part Number: 1044221-00-B
Offset: +40
PCD: 5X114.3
Center Bore: 64.1mm
Weight: 21.6 lbs
Lug Nut Spec: 21mm Hex, 14X1.50 Thread
Lug Nut Torque Spec: 129 lbf
Located in the SF bay area.
Wheel Specs:
Offset: +40
PCD: 5X114.3
Center Bore: 64.1mm
Weight: 21.6 lbs
Still available?
