Have both condenser fans not turning on. Had one louvre vent stuck open which is now fixed.
AC compressor works, revs up to a point then slows down and ends with a click sound. I thought it was the compressor but it works fine and blows cold air when car moves. AC struggles and cuts out when car is stationary like at a stop light then works fine again once the car moves.
Tried swapping relays. Tested relay with a multimeter and it was ok.
Tried to hook up the condenser fan directly to the 12v battery to see if it was the controller causing the problems. The wire got red hot like in a short circuit and the fan didn't move. Seems obvious but to make sure, with the fan disconnected, is it supposed to be very difficult to turn by hand? both fans are very difficult to move by hand and make screeching sounds if I put enough force on them.
