yes they will.
if you keep the offset between 34 and 40 and the bolt pattern to 5x114.3 and the hub at 64.1mm you should be fine as these are the original Tesla specs.
Please make sure that the max load capacity of the wheels meet the max loaded weight of the Tesla. For my model y it 1500kg in the rear and 1350 kg for the front axle so I need a wheel that can carry at least 750kg what is about 1650lbs
