I will likely order a Model 3 within the next 2-3 weeks.
I have been reading about best practices relating to charging the battery to ensure long term health.
The key points seem to be:
-Maintain SOC between 20-80%
-Avoid 100% / 0% SOC
-Frequent slow and shallow charging
The last point implies that frequent use of SuperChargers may not be the most beneficial practice.
The main reason for this may be related to the heat buildup in the battery that naturally occurs when using the SuperCharger.
Which leads to my question: Assuming the above is generally correct, would it be better to use a SuperCharger for short duration - e.g., maximum 10 minute charging session (assuming <80% SOC)? My thought is that the the shorter duration essentially lessens the time that the battery would be subject to the higher temperatures associated with the SuperCharger.
Thoughts?
Thoughts?
