Hello,
Please, experienced responses with the issue only. Let's be pointed to get a result and resolve the issue in this thread.
2016 Model S 75 RWD (May 2016 Refreshed) - Note AC is running perfectly.
My Thermal Test resulted in the Temperature Sensors failure. I also had the left/right rad shutter failure (Not concerned about this yet).
I suspect that both the (1008515-00-C) Low pressure/temperature sensor and (1008516-00-C) High pressure/temperature sensors have failed.
The reason I suspect these 2 sensors is because all other temperature sensors are ok as confirmed from the Thermal Test.
Very simple question: Can someone who experienced this issue confirm which temperature sensors actually failed? Please, informed or technician responses only!
