Swerved to avoid a GIANT pothole and hit the smaller but still ridiculous hole :mad: Wheel is out getting fixed for $210
Reactions: Lindenwood
I recommend 255/35/20 max on a 9" wide wheel. If you'd like to run 275, I suggest a 20x9.5 wheel. You have to make sure the offset is low enough for you to clear the front suspension arm upright.
20" x 9" ET35 American Racing AR924:
BrandAmerican Racing
Product NameAR924 CROSSFIRE
Part NumberAR92429012935
FinishGRAPHITE
MaterialFlow Formed Aluminum
Size20X9
Bolt Pattern5X114.3
Backspace6.38
Offset35mm
Bore72.56
Weight23.15 lbs
Load1400
Lip Size0.00
-Danny
Reactions: mpgxsvcd
2022 RWD
Stock suspension, thinking about coilovers..
KW-Series S18/ZAX YNX 8.5x19 +35
Hankook ventus S1 evo2
Not the wheels I initial was looking for but I got them used in perfect condition for an absolute steal.
Reactions: MODEL+ and FatM3
Trying out these +30 offset 18x8.5” wheels. I feel this offset is so much better than the +40 when it omes to merging with the rest of the car flowlines.
looking at the calculations for the 20"x9" performance uberturbine wheels with 34 offset, and comparing it to this +30 offset for 8.5" wheel, both of them provide almost the same outside rim track width. Performance is 2.35 mm more. So basically, my 18" look is like the performance model.
Hey there! We've got some news for you. Our custom forged wheel service helps create wheels that reflect your style and add a unique touch to your ride.
All you need to do is share an image or description of your desired design, and we'll bring it to life, whether it's a specific pattern, color scheme, or something unique.
Plus, we're offering significant discounts for custom orders:
◼️18" wheels: from $535 to $495 per wheel, saving $160 per set.
◼️19" wheels: from $570 to $525 per wheel, saving $180 per set.
◼️20" wheels: from $645 to $555 per wheel, saving $360 per set.
◼️21" wheels: from $705 to $595 per wheel, saving $440 per set.
◼️22" wheels: from $795 to $655 per wheel, saving $560 per set.
If this sounds like what you're looking for, check out website or send us an email at [email protected] and let's get started on designing wheels that reflect your style.
Take advantage of these discounts, as they will only last until May 31.
Just got the Drag DR-83 18”x8.5” ET30 from Discount Tires mounted with Hankook Ion Evo Summer tires. These are as close as you can get to the uberturbine 20” performance wheels. Per my calculations, the DR-83 are 4mm less track width measured from external rim to rim surface.
Have any regular pictures of the full car (in color) with the wheels? I like the OEM look.
And your math checks out. About 2.3mm less poke, per side, compared to the 20" uberturbines. So basically the same.
Reactions: enemji
Thanks for the validation on the calculation.
My car is black. The wheels are satin graphite grey. The tires are black. So other than the sky & trees, the picture is the same :D
Tsportline sells 20”x10” with 40mm offset for rear wheels. My rough calculation says that it is the same as 20”x8.5” with +20 offset as far as maintaining the outside track width from the rim surface. Am I missing something?
