davewill
I wasn't sure on that point, but I think you're right.I think it’s only older model 3s that are the issue. Model Ys can all easily swap to the ccs ecu without any bundle of wire style hacks.
I've seen a couple people report problems when charging in the cold. I think they were getting an error about the charge port temperature changing too fast, which is likely a result of the "hack" to make the old charge port compatible with the new ECU. (I tried to search quickly to find the posts, but failed.)I ended up just going with the Gen4 ECU + bundle of wires approach. I'm out of my standard warranty, and I've never heard of anyone having an issue DIYing it.
I have not seen any confirmation that Tesla has actually designed the new board that provides CCS comms and properly supports the old charge port configuration. I fully expect that to be the solution offered - a new charge port ECU part number applicable to those Model 3's that have the old charge port. These are the same vehicles that require the "bundle of wires" when used with the Gen4 charge port ECU.My guess is that they either don't want to deal with the hassle of differentiating between the two when ordering the upgrade, or they don't want to divert a significant number of ECUs from production at this point.
Yep, I just checked and there are still just the two CP ECUs listed:I have not seen any confirmation that Tesla has actually designed the new board that provides CCS comms and properly supports the old charge port configuration.
I think there's at least a chance that it will turn out to be the same gen4 board with different firmware. I don't know if that would result in a different part number or not.Yep, I just checked and there are still just the two CP ECUs listed:
Notice they now call the Gen4 one the NACS version, they no longer mention CCS. (I think they did before.)
I maintain that a new ECU part number is the most likely solution. The configuration of temperature sensors and harness is different and a new board is the cheapest and easiest solution to those differences.I think there's at least a chance that it will turn out to be the same gen4 board with different firmware. I don't know if that would result in a different part number or not.
Could also end up being the South Korean variant (they have a CCS compatible gen3 board). In fact, I bet if one was able to import that, it would "just work".I think there's at least a chance that it will turn out to be the same gen4 board with different firmware. I don't know if that would result in a different part number or not.
There are two classes of Model 3/Y cars that don't support CCS. The early M3s that have a gen3 ECU and some 2020/1 M3s and MYs that have a Gen4 ECU in which Tesla didn't populate the powerline comm chip needed for CCS. The latter just need a new ECU, and lots of people have done that upgrade at home. The cars with a Gen3 ECU can DIY upgrade with a Gen4 ECU and a "bundle of wires" hack that makes it work with the older charge port HW on those cars.I’ve never really bought that premise since it’s really only a very limited number of 2017/2018 and some EARLY 2019 M3 that have this CSS limitation with current hardware. Certainly the VOLUME of M3 from 2019 onwards all work with CSS if desired.
My guess is that they just haven't prioritized the time to make a retrofit kit for the old Model 3s. That shouldn't stop them from retrofitting the Gen4 NACS CP ECU into the newer Model 3s and Model Ys, but they likely don't want to deal with it only being available for some Model 3s. (Like happened with the Model 3 powered trunk retrofit.)Well, what is it?
The biggest issue with CCS1 charging (via the adapter) is low battery temps that limit charging speeds. I wish Tesla would allow battery preconditioning when navigating to CCS1 chargers.What speeds are you all getting with the CCS adapter? I get 43kW at EVgo stalls (50 kW/150 kW / 350 kW). I was thinking I should get faster charging speeds at the 150 kW and 350 kW stalls but I guess not.
I get 55v kW at CP 62.5kW stalls.
Driving it is not the same as preconditioning. Preconditioning actually sets a much higher target temp (up to 40C, compared to only 7C for example with regular climate control). At the current cold ambient temps, the battery will likely never get to anywhere near the same temps just by driving it (case may be different in hot weather). Also the kW depends a lot on SOC. What SOC were you at when you saw those numbers? Did you try immediately to supercharge (assuming there is a supercharger nearby) and compare?That does not explain the slow charging. I am arriving after a couple hours of driving so the battery is definitely not cold. This is the case even after charging for long period (meaning battery has heated up), the charge date does not go up. Anyone have a better guess?
Preconditioning Vs. Climate on: Whats the difference?
Again that depends on what your SOC is, which you did not answer. It could be by the time the battery is hot enough, you are already in the taper region. This doesn't happen if you were able to preheat given you arrive at the site with a toasty battery (even in cold weather). Also depending on if you have a PTC or heat pump car, the speed of the heating may vary moving vs stationary, so it's possible your car haven't even reached hot enough temps. This is much easier to diagnose if you have an app like scan my tesla (and OBD2 reader) that allows you to see all the parameters.Again, does not explain the slow charging. During DCFC, the battery heater is activated so you are saying that I should see the charge rate increase as the battery temp increases - but that is not what's happening.
