R RedRedWyyy Member Apr 12, 2023 46 18 SoCal Jun 15, 2023 #1 Jun 15, 2023 #1 Have anyone ran 20x10.5+25 in the front? I’m trying to figure out if it will rub. The tires will probably be 265/35/20 or 265/40/20. TIA!
A AJ Doe Member Dec 3, 2022 12 1 VA Oct 3, 2023 #2 Oct 3, 2023 #2 Were you able to fit 20x10.5 +25 in the front?
MODEL+ Active Member Global Vendor Oct 21, 2020 2,250 2,630 Portland, OR Listings Oct 3, 2023 #3 Oct 3, 2023 #3 Quite aggressive. Would only suggest on moderately lowered MY's. Danny
A AJ Doe Member Dec 3, 2022 12 1 VA Oct 3, 2023 #4 Oct 3, 2023 #4 Danny, Does it mean it will fit on OEM height on MYLR? Wondering if running a square 10.5 +25 offset squared on stock height of a MY is not an issue.
MODEL+ Active Member Global Vendor Oct 21, 2020 2,250 2,630 Portland, OR Listings Oct 3, 2023 #5 Oct 3, 2023 #5 AJ Doe said: Danny, Does it mean it will fit on OEM height on MYLR? Wondering if running a square 10.5 +25 offset squared on stock height of a MY is not an issue. Click to expand... Your wheels/tires will poke out the fenders quite a a bit. It may also rub under extreme suspension compression. Danny
