Aftermarket wheel advise
I currently have a new model 3 performance and recently added 15mm spacers on the front and 20 in the back. I have decided to get new wheels can I get the new wheels in an offset that will match what I have with the spacers and be able to eliminate the spacers altogether?
Stock 20" performance wheels are +34mm offset. Subtract 15mm and 20mm from that for your new desired offset (assuming wheel width is the same). There are some wheel offset calculators online.
Reactions: afadeev
just occurred to me that I would have 2 different wheel sizes to accomplish this. I would like to be able to rotate my tires. Would it be best to match the smallest offset like +19 add 5mm spacers to the rear?
Since you have the spacers why not order +34mm wheels again. Will easier to resell them afterwards
Do take into account that if/when you decide to go with wider tires in the future (to improve handling and tire lifespan), non-OEM offset will severely limit your options, unless you are willing to roll the fenders.
HTH,
a
