So I’d like to install a dedicated dashcam battery pack to power an aftermarket dashcam, separate from the Sentry mode cameras.
I’ve done the install on multiple ICE cars, but in this case I’d love to charge the dashcam battery while I’m charging a Model Y simultaneously, but without also switching the dashcam to driving mode while the battery charges.
Normally a dashcam battery getting power happens when the engine is on which puts the dashcam into driving mode, but I want the dashcam to stay parked while the car itself is parked and charging.
The easiest solution would be to use a basic 2-wire output (instead of a 3-wire with a third ACC wire) from the battery and create a “dumb” connection where the dashcam doesn’t know if the car is on or not based on wiring so it falls back to using the G sensor. This would work. The main downsides are that it would take a few min for the dashcam to switch to parking mode once I’m done driving (not the end of the world) as well as that it could switch to parking recording in times I’m sitting in traffic or otherwise stationary for a few min (which I want to avoid).
The solution I’m thinking of is adding some logic to say the dashcam only records in driving mode when 1) the vehicle ignition is on as usual and 2) the vehicle is not charging.
Does anyone have an idea of where to access wiring specifically for:
1) Constant power
2) ACC / ignition trigger switch
3) Vehicle charging trigger
1) Constant power
