While out for a nightly spin I got a flash on the VDS that seemed to say " DMC Fan Motor Failure .... or Fault" but it flashed on the screen, beeped and went away so fast I didn't really see it. I thought of the PEM cooling fans but while driving I kept checking the temps and nothing was abnormal. When I got home I plugged 992 in and issued a "cooldowm" command on the OVMS and cooling started normally BUT after two minutes I got this: "DMC FW: HCS Faulted Warning"! Cooldown paused.........
Anybody seen this??? :crying:
Issued a second cooldowm request and nothing happened....... No charging at all.
Started a standard charge by pushing "charge now" on VDS one charging started and seems to be running in "Range Charge"! The front AC fans engaged for awhile but stopped after a few minutes.
Battery at 82f, motor at 109f; PEM at 104 F charging continues.
