Thus far, there are literally hundreds of threads about autonomous cars on the Tesla forum,
mostly about technological developments, company's claims and pitches, the implications
economically, regulatory and legally, about testing and pilots, user experiences and a lot of
what I call 'semantics' (how to define and value the many different aspects in VA).
So far, it looks like the 'spatial dimension' is missing, which is odd since going from A to B still
requires some sort of physical transport mode... that we now decided to make driverless.
It as if car makers and AV developers have jointly decided that vehicle size does not matter,
shouldn't matter. Now I know that an AV setup is that costly, that only more expensive,
therefore bigger cars are used for (preliminary) testing.
The bigger the AV:
- the less space there is to maneuver through traffic
- the less margin there is to take evasive action
- the harder it is to scan - sensor - image its vicinity
- the more likely they will cause accidents (say IIHS, NHTSA and ETSC)
This is an older article (which shows you how rapid developments are),
but it basically says that smaller vehicles are easier to deploy autonomously.
Might do without tens of dollars in AV setups.
THE beautiful catch of course is that greening the car (the smaller, the less kWh needed)
and making it driverless can be two sides of that same highly coveted coin.
What say you?
The bigger the AV:
Autonomous Vehicles Should Start Small, Go Slow
Self-driving vehicles can already work well on campuses where traffic moves slowly
spectrum.ieee.org
What say you?
