Hey folks,
A week or so back, I posted the video below with a sound I'm hearing from the front end of my P90D. Since then, here's what I've found out:
1) It's coming from both sides, independent of each other.
2) It's actually not the suspension - all components are in good shape and torqued to spec.
3) I hear the noise when I go over sharp changes in road surface (like two concrete plates with a gap between them), not 'smoother bumps'
So, since I hear it from each side, independent of the other, when I go over the same types of bumps on either side, and it's not the suspension, I figure it must be something connecting one side to the other.
Last year the SC replaced my steering rack, and the car has made noises in the front ever since. I'm not sure it's the actual steering rack, that seems to be tight....and it it was moving, I'd think my steering would suck.
The only thing I can think of substantial enough to make such a noise is the Front Subframe....I'm curious if the subframe bolts are loose. I plan to check the bolts below to see if they're torqued down....any other ideas?
![B8B0YvG.png](https://i.imgur.com/B8B0YvG.png)
