Everyone I was looking back at rated range numbers of my newly acquired 2016 P90 DL and I’m not seeing differences between the 19s and 21s like they do now.
On my plan, it was about a 34 km difference, so I’m wondering what it would be on this car?
On my second charge I got 394 and it’s set up with 21s I guess I could go to the configuration and switch it to 19 and see what it reports? I can’t check at the moment as I’m trying a procedure to better balance the cells. I’ve already added 9 km since I’ve got it. It’s now 394 up from 385 with a little TLC
Now I’m trying this procedure. What do you think of it? I’ve already run it down to 5%. It was a little scary coming home! Now letting it sit at its low SOC.
For a more accurate idea of how much capacity loss your battery has, I would suggest doing the following:
1. Run the battery down below 10% SOC - around 5% is ideal.
2. This is important: Let the vehicle sit at this low state of charge for at least 12 hours.
3. Using a level 2 charger, charge the car to 100%. When it reaches 100%, let it sit on the charger for at least another 5 hours.
This will allow the pack to balance as much as possible and will let the BMS update its algorithm. At this point, the range displayed on your screen should be the most accurate representation of the battery's state of health. Some folks will see a small range bump after doing this procedure.
