Vendor How to Install Lasfit Door Sill Protector on Tesla Model 3 and Model Y
LASFIT door sill protector is specially designed for Tesla Model 3 2017-2023 and Tesla Model Y 2020-2023. It is made of TPE material, which not only protects the door sill from scratches, abrasion, kicks and stains, but also can be an exquisite interior accessory. Suitable for all weather and road conditions, protect your car from mud, sand, rocks, rain, snow, salt, and other debris. Prevents scratches and keeps the car body clean.
1. Table Of Contents
Accessories
Installation Instructions
Effect picture after installation
Attention
FAQ
Where Can I Buy Lasfit Door Sill Protector?
2. Accessories
Lasfit Door Sill Protectors Include:
● Front Door Sill Protectors(Left and Right)*2
● Rear Door Sill Protectors(Left and Right)*2
● User Manual *1
3. Installation Instructions
Step 1:Clean the door sill with a towel.
Step 2:Ensure that the product corresponds to the correct location.
Step 3:Tear off the back of the double-sided adhesive at one end, then find the correct positon.
Step 4:Tear off the rest of the double-sided adhesive, stick on and press firmly.
Step 5:Pry out the soft rubber on the door to wrap around the edge the product.
4. Attention
1. When receiving the package, please check whether the accessories are complete before installation.
2. The use temperature of the product is -30 ℃ to 80 ℃. To ensure the product can work well, please do not stay in extreme temperature for a long time.
3. When you find the product is deformed and cannot be restored, please disassemble it in time to prevent accidental trips and falls.
4. The front door sills will be folded and packed for easier transportation. If there is any crease, please fold it in the opposite direction, or unfold it and put it in the sun for 1-2 hours to help restore shape.
5. To ensure the proper function of double-sided adhesive, please do not disassemble the product after installation. If you want to clean it, please wipe it with a wet cloth.
6. Please do not use alcohol with a concentration of more than 30% to clean the product.
5. Effect picture after installation
6. FAQ
Q1: Will it hurt the original car interior?
A1: Our door sill protector is made of high-quality TPE material with a soft texture, which will not harm the original car door sills and will not leave marks on the car after disassembly.
Q2: What should I do if the product doesn't stick well after long time use?
A2: You can replace the double adhesive to a much stronger one.
Q3: Does this item fit Tesla Model 3 2022?
A3: Yes, this product is specifically customized for Model 3. It fits 2022 Model 3 perfectly.
Q4: Are they easy to clean?
A4: Yes, our door sill protectors are made of TPE, waterproof, and very easy to clean, just wipe them with a wet rag.
Q5: Are they waterproof?
A5: Yes waterproof! Even muddy water can be wiped off quickly.
7. Where Can I Buy Lasfit Door Sill Protector?
If you are going to use Lasfit Door Sill Protector to upgrade your vehicle, please click the link below or login to our LASFIT official webpage to choose. 👉 Lasfit Tesla-Specific Protective Products
💭Questions or Comments? Leave them below!
Thank you all for your support to Lasfit!
