I added an ethernet cable between my Gateway 2 and a local hub. I already have two Zigbee black boxes from Tesla (pictured).
The first one came with my original 11 panel system and the second from a second set of 12 panels and a PW.
Does my newly installed ethernet cable make my Zigbee boxes redundant such that I can remove them?
Note: I also added 3 12v fans to the top of my SolerEdge inverter as the garage can get hot in the summer. The fans pull room air up through the bottom of the heat sink and exhausts it out the top. Drops the air temps 10 degrees or so. The fans are on a timer to run during the hot part of summer days.
Thanks.
EDIT: The white box on the SolarCity inverter is a Wyze camera to monitor realtime solar generation since the Tesla app is not always real time.
EDIT: Added photo of ethernet Female/Female feedthrough installed on lower right side back knockout of Gateway 2. From Amazon.
Thanks.
