Hi
Is Expel ultimate plus ppf better than 3M ppf? I heard on YouTube that 3M gives a $3500 warranty against rock chips that expel does not provide but could not find any reference to this warranty on 3M’s website.
Regards
S
Hi jkoyaI had full exterior Xpel Ultimate Plus installed by @Premiertint in El Dorado Hills. Extremely happy with the product and the install. Even if you don't opt for the full exterior, I would highly recommend getting the rocker panels wrapped.
Hi jkoya
If you do not mind, can you please tell me how much did it cost you?
Regards
S
I had Xpel on my mercedes and didn't like it, the edges lifted quite easily which led to dirt getting under. The "solution" was to trim the pieces instead of replacing them which was lame.
I went with Suntek this time around and it's pretty much transparent on my white car. The general consensus is that Suntek provides the best visuals for the car.
I honestly don't think you can go wrong with Suntek or Xpel, I'd avoid 3M as the original yellowing issue started with their film - I'm sure it has been corrected since, but that type of fault shouldn't be ignored.
The #1 issue you should be focused on is installer and if they wrap edges. Some will just use pre-cut pieces and don't give a flip if seams show. Spend more time finding an installer that just doesn't use pre-cuts and if they do, make sure they wrap the edges and you can confirm that from reviews.
Hi @SunTek,
I have a quick question for you. I had SunTek PPF installed on my Acura NSX in April of 2015. The edges of the side mirrors were not fully wrapped and now on the driver's side mirror, the edges have lifted. What is the best way to remove the PPF ?
I used your link to find a SunTek installer and the closest one to Sacramento is 65 miles away (Concord, CA) and the original installer is 123 miles away (San Jose, CA).
My apologies for hijacking this thread ........
You could also send them a PM (open a conversation) as not to highjack the thread...
Just thought of that after I hit post reply ......senior moment !!
Auto Armour in San Diego, $7000.00 full wrap.if you dont mind my asking, was it over or under 6500?
