Hello all, I recently lowered my 2021 S LR+ raven with 3D printed links. I used Scotts (RIP) 3D print file and used 74mm rear and 54mm front length links. The issue is right now the front sits a bit higher than the rear (I think the cars come standard like this) so I want to possibly use slightly longer links in the fronts so that I can lower just the front a bit more. Off the top of my head I can't think this would be an issue, but just wanted to see if anyone has a better insight. I think if anything it will aid handling since the front sits a bit lower but the changes are only going to be a few mm that it may be negligible.
