MYP wheels sizing
I'm looking to upgrade my 23 MYP wheels to a 20" wheels. Will this setup works for the 23 MYP? The offset is off by 10 from the OEM wheels. Also am I able to go with the 40 rear and 35 front? Thanks for any suggestion.
Wheel Size (Front): 20x9 inches Offset +30Wheel Size (Rear): 20x10 inches Offset +34Tires (Front): Michelin Pilot Sport 4S - 255/35 ZR20Tires (Rear): Michelin Pilot Sport 4S - 293/30 ZR20
I have a square set of 19” +35 wheels for my MYP. So the offset should be fine.
Both 255/35/20 and 293(295?)/30/20 tires are smaller than factory spec’s 255/40/20. They’re both about 27” while factory tires (for all wheels) are 28” (or more for the MYP rear).
If you’re asking if they’d fit… probably. But would you want them at that size?
Moving them up one step in aspect ratio would match factory better.
