"Easy Entry" is just a profile on these cars, not much different than having a profile for another driver. Did you adjust the seat, steering wheel, etc while the easy entry profile was active? The plus side of that is, you can set the easy entry profile to do what you want (how far the seat slides back, the angle of the steering wheel and if its pushed all the way in, etc).
The negative part is that you need to adjust all that at least once, otherwise nothing happens when you use the easy entry profile as I believe your current settings are being used as the easy entry profile settings as well.
