If you are looking for a nicely integrated bass / subwoofer upgrade for your 5-seater Y but don’t want to take up too much space, this is a great option. The only loss to space is the “milk” pockets on either side of the rear storage area. Or one pocket if you install a single side. You can add the second side later to save some $ but it is a bit easier to do it all at once.
nvx.com
I installed both the driver and passenger side and would rate the install a 5 out of 10, very doable if you have some experience. Take your time when removing panels and taking pictures will help with reassembly and clip locations. Strongly recommend a full system shutdown including disconnecting the high voltage interlock loop and negative battery terminal before connecting the 12V power cable to the penthouse. The bolt in that area is positioned in a way that could easily short using a ratchet so it is best to power down. You can find the process below. It is nice to not have to pull 12V power all the way from the frunk 12V battery, saves time. Would be nice if NVX provided molex connectors that went between the factory amp and the aftermarket amp to prevent the need to splice into factory wiring for signal and LOC power.
www.ohmmu.com
Fit and finish is very nice and the bass is strong, yet balanced once properly tuned. Don’t expect “hair tricks” but it is great #DADBASS. I do think these subs would hit harder if given 500 watts RMS each but worry about pulling too many amps from the penthouse / 12V battery and receiving 12V issues. Someone else can test 1000 watts RMS at 1 ohm (for both sides) and report back. Rattles in the vehicle are surprisingly minimal.
Have been running this setup for about a month and have had no issues. This setup produces 500W total at 1 ohm (both sides). If you purchase a single side it would be 320 watts RMS using their amp. The amp is crazy small, no idea how it puts out this much power.
Not sure if this impacts range much but was not concerned about it. If it does I don’t really notice and the tradeoff is worth it. My remote bass knob is near the seat controls. Easy to access and not permanent. Songs can have unique bass characteristics (especially when switching sources) and I seem to adjust it a lot to dial in the desired impact.
Happy to answer questions and before you ask, not sure how Tesla SC will react when they see this. Not incredibly difficult to uninstall if you have to, maybe take 45 minutes.
![nvx.com](https://nvx.com/cdn/shop/collections/All_NVX_BOOST_Boxes_1200x1200.jpg?v=1659371833)
Vehicle Specific Loaded Subwoofer Enclosures
Check out NVX’s loaded subwoofers made with your vehicle in mind. Designed and test-installed by our team, our BOOST Boxes come with clear instruction manuals and all the accessories you need to get the show on the road.
![nvx.com](https://nvx.com/cdn/shop/files/favicon_32x32.png?v=1659380640)
![www.ohmmu.com](https://static.wixstatic.com/media/8074b0_293e6bd11b164bb0b7521b7201524fc9%7Emv2.jpg/v1/fit/w_2500,h_1330,al_c/8074b0_293e6bd11b164bb0b7521b7201524fc9%7Emv2.jpg)
Tesla Model 3 - 12V Battery Install Video
Learn how to swap the 12V battery in your Tesla Model 3.
![www.ohmmu.com](https://static.wixstatic.com/media/8074b0_3ed1b977f8464530b485b3419ac586e3%7Emv2.png/v1/fill/w_192%2Ch_192%2Clg_1%2Cusm_0.66_1.00_0.01/8074b0_3ed1b977f8464530b485b3419ac586e3%7Emv2.png)
