FRUNK Access > can we have a code to protect larger items.
Similar to the Glove Box.
I lost my Charger recently. Probably where I had my tires done.
Thanks
Learn how to open and close the front trunk and access the cargo area.
www.tesla.com
Opening Hood with No Power
In the unlikely event that Model 3 has no low voltage power, you will be unable to open the front trunk using the touchscreen, key fob, or mobile app. To open the front trunk in this situation:
Note The following steps do not open the front trunk if Model 3 is locked and has low voltage power.
Locate an external low voltage power supply (such as a portable jump starter).
Release the tow eye cover by pressing firmly on the top right perimeter of the cover until it pivots inward, then gently pulling the raised section toward you.
Note
Depending on production date, either the positive or negative terminal may be attached to the tow eye cover.
