After going through winter and finally getting around to manual cleaning of the car I was disappointed to see one of the black screws leaving a rust trail on my licence plate. I had this happen on my last car too and it damaged the paint.
Here's what I did to remedy the situation.
My first thought was that I'd pull it out and put in a nylon screw. After taking the screw out I found that I couldn't find a nylon screw that would work. The model 3 uses a type of self tapping metal screw that is driven in to a plastic mount.
I decided that if I couldn't make it all plastic, my next option would be to use stainless steel. All of the stainless screws that I could find didn't have a big enough head. Even the stock screw wasn't properly sized to fit the plate holes.
In the end I went with the following that I could find at Canadian Tire:
-Stainless steel #10 x 1/2" sheet metal screws
-#12 flat washers (I couldn't find #10 with a wide enough diameter)
These just replaced the existing screws. Hopefully these will resist corrosion and rust. Let me know if you find any better solutions.
