Up for sale is a pair of NEW MPP Caster Adjustable Compression Rod Bearings pressed into USED Factory Tesla Compliance Link Housings.
Save the time and aggravation of pressing new bushings into your existing front lower compression arms/compliance links.
Using good, used cores with sound ball joints, I pressed out the factory bushings and replaced them with MPP Solid Bearings!
Fits: 2017-2023 Tesla Model 3, 2020-2023 Tesla Model Y
Detail on MPP Bearings: The ultimate upgrade for those looking for a no-compromise solid front suspension!
- CNC machined from billet 6061-T6 aluminum
- Manufactured and Assembled in North America!
- Sealed spherical bearing, for maximum longevity and reduced noise.
- Caster adjustable – using our unique design the caster can be adjusted by rotating the bearing.
- Gain confidence – massive reduction in darting and steering wheel shake during aggressive braking
- Can be used with our Front Lower Control Arm Bearings and Front Upper Control Arms to eliminate ALL rubber bushings in the Model 3’s front suspension.
