Tire pressure
Hi this may be a dumb question but I’ve attached a photo to this post was wondering if these uneven pressures would be alright for my tires.. I could never get them all the same. Thanks in advance
Nothing wrong with them having a delta of 1-2psi tire to tire and across all four.
However, a. you should be able to get then closer (better auto-shut off inflator?) b. should consider raising the cold tire pressure a bit if on any stock size tire/wheel combo (say 46psi all around, or even 48psi)
c. set your own TPMS default nominal pressure (use the TPMS sensor reset menu)
Reactions: Liangfever
Upvote 0
They are fine. If 42 recommended I put 44 cold tire pressure. When inflating I use a hand gauge. I overshoot the pressure a small amount then tap the valve letting small amounts out and checking to get it where I want it.
Upvote 0
