  • The final cut of TMC Podcast #27 is available now with topics time-stamped. We discussed: Consolidation in LiDAR manufacturers; Volvo EX90 shipping with LiDAR; FSD Beta Full Release in N.A.; FSD detecting autopilot cheats, Gwen Shotwell directly overseeing SpaceX Starship; and more. You can watch it now on YouTube. We should have it published to podcast networks shortly.
Using same size different brand wheels and its effect on AWD
Hey fellow Tesla owners.
I am here with another question.
I googled a bit and there are different ideas out there. But most of them are for 4x4 combustion engines.
I couldn't find anything about electricle vehicles, let alone Teslas.
I found a second hand 21" Arachnid for quite a good price and I am tempted so I am looking into buying tires..
So, the question is..
Would it be a problem to use 2x 265/35/21 Goodyear Eagle F1 Asymmetric 5 for the rear wheels, and 2x 245/35/21 Continental EcoContact 6 front wheels?
The reason I am asking this is for consumption efficiency.
Continental EcoContact 6:
245/35/21 EU LABEL -> Wet grip: A / Fuel Efficiency: B
265/35/21 size doesn't exist
Goodyear Eagle F1 Asymmetric 5:
245/35/21 EU LABEL -> Wet grip: A / Fuel Efficiency: C
265/35/21 EU LABEL -> Wet grip: A / Fuel Efficiency: B
You see, if I go for a set of Goodyear, I end up with Fuel efficiency C on the front tires.
I can't go 4x Continental EcoContact because 265/35/21 doesnt exist.
So If I go Goodyear for rear and Conti for front, I get B A labels for both front and rear wheels.
But the question is, is the fact that front and rear wheels will have different tire patterns dangerous for driving dynamics and / or harmful for the car's mechanics?
Snow Drift
[Off-Road Assist] Activated
Feb 10, 2016
2,087
1,650
Long Island
You aren't supposed to mix tires, ever. That could just be for marketing, but it's the usual suggestion.
As long as the tires on each axle are the same size it should not be a problem for the car. If they are different then they spin at different rates which can cause issues with the differential, etc.
The stock staggered front/rear are different heights, but within acceptable difference (3% max)
Yess, the diameter and rpm difference problems I am aware of.
But in this case it would be front axle one type, rear axle another type tires of same size / radius.
Just the pattern will be different and that makes me curious.
Snow Drift
Feb 10, 2016
2,087
1,650
Long Island
Why do you want All-Season tires? Why not just get great Summer tires and great Winter tires?
Snow Drift
Feb 10, 2016
2,087
1,650
Long Island
No, there is no danger. You should always put your best performing tires in the rear. This is generally the advice if someone replaces only two tires of a matched set, but you won't have an issue. It certainly isn't dangerous. However, It is still recommended to run matching tires for the best performance.
Reactions: tezcatcatl
Goodyear Eagle F1 Asymmetric 5 | Luxurious comfort tyre | Goodyear tyre
Goodyear's own website lists them as summer tires. (Zomer means summer in Dutch).
And the tread also doesn't look like 4 season tires at all to me :S
Snow Drift
Feb 10, 2016
2,087
1,650
Long Island
Very weird. The Tesla Model Y w/ optional 20" Induction rims are mounted with Goodyear Eagle F1 Asymmetric 5 All-Seasons (M+S = Mud & Snow)
See bottom of tire here:
