Both of my used Model 3's did not come with license plate screws. If you're in the same boat, the size you need is 5mm 0.8 x 6mm if you're mounting it without a frame. I use a clear cover and frame, which makes it a bit thicker. Thus the screws I used are 5mm 0.8 x 10mm. This was a perfect fit...
